Modulefpreviousupnextcontents[BIG][Normal][small]
Next: Part II: Graphics Up: 3 Manipulation of structures and miscellaneous Prev: 3.7 Eigenvalues and eigenvectors of a Contents
3.8 Miscellaneous
Compression of a D.S. MUA (module CCMUA) or AMAT (module CCAMAT).
      SUBROUTINE CCMUA(M,RAPORT,NFMUAE,NIMUAE,NFMUAS,NIMUAS)
C +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
C AIM : COMPRESS THE I.D.S. MUA BY RETAINING ONLY THE COEFFICIENTS
C ---   A(I,J) IN EACH ROW I BELOW THE 1ST SUPERIOR OR EQUAL TO
C       ABS(A(I,I)) * RATIO FOR I=1,...,NTDL
where
      SUBROUTINE CCAMAT(M,RAPORT,NFAMAE,NIAMAE,NFAMAS,NIAMAS)
C ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
C AIM : COMPRESS THE I.D.S. AMAT BY RETAINING ONLY THE COEFFICIENTS
C ---   A(IJ) SUCH THAT ABS(A(I,J)) >= RATIO * ABS(A(I,I)) I=1,...,NTDL
where
