Interfacing function
eng
ANDBLK
File content
function [x,y,typ]=ANDBLK(job,arg1,arg2)
// Copyright INRIA
x=[];y=[],typ=[]
select job
case 'plot' then
  standard_draw(arg1)
case 'getinputs' then
  [x,y,typ]=standard_inputs(arg1)
case 'getoutputs' then
  [x,y,typ]=standard_outputs(arg1)
case 'getorigin' then
  [x,y]=standard_origin(arg1)
case 'set' then
  x=arg1
case 'define' then
  andlog=ANDLOG_f('define')
    andlog.graphics.orig=[194,133]
    andlog.graphics.sz=[60,60]
    andlog.graphics.flip=%t
    andlog.graphics.pout=9
    andlog.graphics.pein=[4;11]
  input_port1=CLKIN_f('define')
    input_port1.graphics.orig=[149,287]
    input_port1.graphics.sz=[20,20]
    input_port1.graphics.flip=%t
    input_port1.graphics.exprs='1'
    input_port1.graphics.peout=4
    input_port1.model.ipar=1
  output_port=CLKOUT_f('define')
    output_port.graphics.orig=[450,83]
    output_port.graphics.sz=[20,20]
    output_port.graphics.flip=%t
    output_port.graphics.exprs='1'
    output_port.graphics.pein=8
    output_port.model.ipar=1
  input_port2=CLKIN_f('define')
    input_port2.graphics.orig=[141,330]
    input_port2.graphics.sz=[20,20]
    input_port2.graphics.flip=%t
    input_port2.graphics.exprs='2'
    input_port2.graphics.peout=6
    input_port2.model.ipar=2
  ifthel=IFTHEL_f('define')
    ifthel.graphics.orig=[331,137]
    ifthel.graphics.sz=[60,60]
    ifthel.graphics.flip=%t
    ifthel.graphics.pin=9
    ifthel.graphics.pein=12
    ifthel.graphics.peout=[8;0]
  split=CLKSPLIT_f('define')
    split.graphics.orig=[234;275.78348]
    split.graphics.pein=6,
    split.graphics.peout=[11;12]
  diagram=scicos_diagram()
    diagram.objs(1)=andlog
    diagram.objs(2)=input_port1
    diagram.objs(3)=output_port
    diagram.objs(4)=scicos_link(xx=[169;214;214],yy=[297;297;198.71],..
				ct=[5,-1],from=[2,1],to=[1,1])
    diagram.objs(5)=input_port2
    diagram.objs(6)=scicos_link(xx=[161;234;234],yy=[340;340;275.78],..
				ct=[5,-1],from=[5,1],to=[10,1])
    diagram.objs(7)=ifthel
    diagram.objs(8)=scicos_link(xx=[351;351;450],yy=[131.29;93;93],..
				ct=[5,-1],from=[7,1],to=[3,1])
    diagram.objs(9)=scicos_link(xx=[262.57;322.43],yy=[163;167],..
				 ct=[1,1],from=[1,1],to=[7,1])
    diagram.objs(10)=split
    diagram.objs(11)=scicos_link(xx=[234;234],yy=[275.78;198.71],..
				 ct=[5,-1],from=[10,1],to=[1,2])
    diagram.objs(12)=scicos_link(xx=[234;361;361],yy=[275.78;275.78;202.71],..
				 ct=[5,-1],from=[10,2],to=[7,1])
    x=scicos_block()
    x.gui='ANDBLK'
    x.graphics.sz=[2,2]
    x.graphics.gr_i=list('xstringb(orig(1),orig(2),''ANDBLK'',sz(1),s"+...
			 "z(2),''fill'')',8);
    x.graphics.pein=[0;0]
    x.graphics.peout=0
    x.model.sim='csuper'
    x.model.evtin=[1;1]
    x.model.evtout=1
    x.model.blocktype='h'
    x.model.firing=%f
    x.model.dep_ut=[%f %f]
    x.model.rpar=diagram;
end
endfunction
