function [x,y,typ]=CSCOPXY(job,arg1,arg2) // Copyright INRIA x=[];y=[];typ=[] select job case 'plot' then standard_draw(arg1) case 'getinputs' then [x,y,typ]=standard_inputs(arg1) case 'getoutputs' then x=[];y=[];typ=[]; case 'getorigin' then [x,y]=standard_origin(arg1) case 'set' then x=arg1; graphics=arg1.graphics;exprs=graphics.exprs model=arg1.model; //dstate=model.dstate; while %t do [ok,nbr_curves,clrs,siz,win,wpos,wdim,xmin,xmax,ymin,ymax,N,exprs]=getvalue(.. 'Set Scope parameters',.. ['Number of Curves'; 'Color (>0) or mark (<0)'; 'Line or mark size'; 'Output window number (-1 for automatic)'; 'Output window position'; 'Output window sizes'; 'Xmin'; 'Xmax'; 'Ymin'; 'Ymax'; 'Buffer size'],.. list('vec',1,'vec',1,'vec',1,'vec',1,'vec',-1,'vec',-1,'vec',1,'vec',1,.. 'vec',1,'vec',1,'vec',1),exprs) if ~ok then break,end //user cancel modification mess=[]; if size(wpos,'*')<>0 &size(wpos,'*')<>2 then mess=[mess;'Window position must be [] or a 2 vector';' '] ok=%f end if size(wdim,'*')<>0 &size(wdim,'*')<>2 then mess=[mess;'Window dim must be [] or a 2 vector';' '] ok=%f end if nbr_curves<=0 then mess=[mess;'Number of Curves cannot be negative or null';' '] ok=%f end if win<-1 then mess=[mess;'Window number cannot be inferior than -1';' '] ok=%f end if N<1 then mess=[mess;'Buffer size must be at least 1';' '] ok=%f end if N==1 & clrs>0 then mess=[mess;'Buffer size must be at least 2';' '] ok=%f end if ymin>=ymax then mess=[mess;'Ymax must be greater than Ymin';' '] ok=%f end if xmin>=xmax then mess=[mess;'Xmax must be greater than Xmin';' '] ok=%f end if ~ok then message(mess) else in = nbr_curves*ones(2,1); in2 = ones(2,1); [model,graphics,ok]=set_io(model,graphics,list([in in2],ones(2,1)),list(),ones(1,1),[]); if wpos==[] then wpos=[-1;-1];end if wdim==[] then wdim=[-1;-1];end rpar=[xmin;xmax;ymin;ymax] ipar=[win;1;N;clrs;siz;1;wpos(:);wdim(:);nbr_curves] //if prod(size(dstate))<>2*N+1 then dstate=-eye(2*N+1,1),end //model.dstate=dstate; model.rpar=rpar;model.ipar=ipar graphics.exprs=exprs; x.graphics=graphics;x.model=model break end end case 'define' then win=-1; clrs=4;siz=1 wdim=[600;400] wpos=[-1;-1] N=2; xmin=-15;xmax=15;ymin=-15;ymax=+15 nbr_curves = 1; model=scicos_model() model.sim=list('cscopxy',4) model.in=[1;1] model.in2=[1;1] model.intyp=[1;1] model.evtin=1 model.rpar=[xmin;xmax;ymin;ymax] model.ipar=[win;1;N;clrs;siz;1;wpos(:);wdim(:);nbr_curves] model.blocktype='d' model.dep_ut=[%t %f] exprs=[string(nbr_curves); sci2exp(clrs); sci2exp(siz); string(win); sci2exp([]); sci2exp(wdim); string(xmin); string(xmax); string(ymin); string(ymax); string(N)]; gr_i=['thick=xget(''thickness'');xset(''thickness'',2);'; 't=(0:0.2:2*%pi)'';'; 'xx=orig(1)+(1/5+(cos(3*t)+1)*3/10)*sz(1);'; 'yy=orig(2)+(1/4.3+(sin(t+1)+1)*3/10)*sz(2);'; 'xpoly(xx,yy,''lines'');'; 'xset(''thickness'',thick)'] x=standard_define([2 2],model,exprs,gr_i) end endfunction
