Programming scicos blocks
fr - eng
C_macros - Utilities C macros
Contents
Module
Description
The following C macros are avialable by including the file scicos_block4.h in a C computational function.
Inputs/outputs
Macro Description
GetNin(blk) Get number of regular input port.
GetInPortRows(blk,x) Get number of rows (first dimension) of regular input port number x.
GetInPortCols(blk,x) Get number of columns (second dimension) of regular input port number x.
GetInPortSize(blk,x,y) Get regular input port size number x. (y=1 for the first dimension, y=2 for the second dimension)
GetInType(blk,x) Get type of regular input port number x.
GetInPortPtrs(blk,x) Get regular input port pointer of port number x.
GetRealInPortPtrs(blk,x) Get pointer of real part of regular input port number x.
GetImagInPortPtrs(blk,x) Get pointer of imaginary part of regular input port number x.
Getint8InPortPtrs(blk,x) Get pointer of int8 typed regular input port number x.
Getint16InPortPtrs(blk,x) Get pointer of int16 typed regular input port number x.
Getint32InPortPtrs(blk,x) Get pointer of int32 typed regular input port number x.
Getuint8InPortPtrs(blk,x) Get pointer of uint8 typed regular input port number x.
Getuint16InPortPtrs(blk,x) Get pointer of uint16 typed regular input port number x.
Getuint32InPortPtrs(blk,x) Get pointer of uint32 typed regular input port number x.
GetSizeOfIn(blk,x) Get the sizeof of the regular input port number x.
GetNout(blk) Get number of regular output port.
GetOutPortRows(blk,x) Get number of rows (first dimension) of regular output port number x.
GetOutPortCols(blk,x) Get number of columns (second dimension) of regular output port number x.
GetOutPortSize(blk,x,y) Get regular output port size number x. (y=1 for the first dimension, y=2 for the second dimension)
GetOutType(blk,x) Get type of regular output port number x.
GetOutPortPtrs(blk,x) Get regular output port pointer of port number x.
GetRealOutPortPtrs(blk,x) Get pointer of real part of regular output port number x.
GetImagOutPortPtrs(blk,x) Get pointer of imaginary part of regular output port number x.
Getint8OutPortPtrs(blk,x) Get pointer of int8 typed regular output port number x.
Getint16OutPortPtrs(blk,x) Get pointer of int16 typed regular output port number x.
Getint32OutPortPtrs(blk,x) Get pointer of int32 typed regular output port number x.
Getuint8OutPortPtrs(blk,x) Get pointer of uint8 typed regular output port number x.
Getuint16OutPortPtrs(blk,x) Get pointer of uint16 typed regular output port number x.
Getuint32OutPortPtrs(blk,x) Get pointer of uint32 typed regular output port number x.
GetSizeOfOut(blk,x) Get the sizeof of the regular output port number x.
Events
Macro Description
GetNevIn(blk) Get the input event number.
GetNevOut(blk) Get number of event output port.
GetNevOutPtrs(blk) Get pointer of event output register.
Parameters
Macro Description
GetNipar(blk) Get number of integer parameters.
GetIparPtrs(blk) Get pointer of the integer parameters register
GetNrpar(blk) Get number of real parameters.
GetRparPtrs(blk) Get pointer of the real parameters register.
GetNopar(blk) Get number of object parameters.
GetOparType(blk,x) Get type of object parameters number x.
GetOparSize(blk,x,y) Get size of object parameters number x. (y=1 for the first dimension, y=2 for the second dimension)
GetOparPtrs(blk,x) Get pointer of object parameters number x.
GetRealOparPtrs(blk,x) Get pointer of real object parameters number x.
GetImagOparPtrs(blk,x) Get pointer of imaginary part of object parameters number x.
Getint8OparPtrs(blk,x) Get pointer of int8 typed object parameters number x.
Getint16OparPtrs(blk,x) Get pointer of int16 typed object parameters number x.
Getint32OparPtrs(blk,x) Get pointer of int32 typed object parameters number x.
Getuint8OparPtrs(blk,x) Get pointer of uint8 typed object parameters number x.
Getuint16OparPtrs(blk,x) Get pointer of uint16 typed object parameters number x.
Getuint32OparPtrs(blk,x) Get pointer of uint32 typed object parameters number x.
GetSizeOfOpar(blk,x) Get the sizeof of the object parameters number x.
States and work
Macro Description
GetNstate(blk) Get number of continuous state.
GetState(blk) Get pointer of the continuous state register.
GetDstate(blk) Get number of discrete state.
GetNdstate(blk) Get pointer of the discrete state register.
GetNoz(blk) Get number of object state.
GetOzType(blk,x) Get type of object state number x.
GetOzSize(blk,x,y) Get size of object state number x. (y=1 for the first dimension, y=2 for the second dimension)
GetOzPtrs(blk,x) Get pointer of object state number x.
GetRealOzPtrs(blk,x) Get pointer of real object state number x.
GetImagOzPtrs(blk,x) Get pointer of imaginary part of object state number x.
Getint8OzPtrs(blk,x) Get pointer of int8 typed object state number x.
Getint16OzPtrs(blk,x) Get pointer of int16 typed object state number x.
Getint32OzPtrs(blk,x) Get pointer of int32 typed object state number x.
Getuint8OzPtrs(blk,x) Get pointer of uint8 typed object state number x.
Getuint16OzPtrs(blk,x) Get pointer of uint16 typed object state number x.
Getuint32OzPtrs(blk,x) Get pointer of uint32 typed object state number x.
GetSizeOfOz(blk,x) Get the sizeof of the object state number x.
GetWorkPtrs(blk)(blk) Get the pointer of the Work array.
Zero crossing surfaces and modes
Macro Description
GetNg(blk) Get number of zero crossing surface.
GetGPtrs(blk) Get pointer of the zero crossing register.
GetNmode(blk) Get number of modes.
GetModePtrs(blk) Get pointer of the mode register.
Authors
Alan Layec INRIA
