Scicos Palette
fr - eng
Integer palette
\epsfig{file=Integer_pal.eps,height=4.2cm}
Module
Description
That palette is dedicated to handle integer numbers. Various basic operators for the management of bit fields and for logic are implemented as well as common gates encountered in digital circuits.
Blocks
