Scicos Palette
fr - eng
Sources palette
\epsfig{file=Sources_pal.eps,height=11cm}
Module
Description
Most of blocks of the Source palette can be viewed as data generators. That palette also contains blocks to read data from files and input ports used in superblocks.
The blocks of that palette doesn't have regular input ports.
Blocks
