Scilab Function
eng
add_palette
File content
function add_palette(Title,path)
//## Add a palette to the end of the list of the scicos palette.
//## If the palette exists with same Title and same path
//## noting is done. If a palette with same name but
//## different path exist then the palette is added
//## with a suffixe (x)
//## Note that scicos_pal variable is locally recreated
//## and passed to the upper environnement via
//## scicos_pal=resume(scicos_pal)
//## Inputs :
//## Title : the title of the palette
//## path  : the path + name of the cos or cosf file
//##         that contains the palette
  if exists('scicos_pal') then
    scicos_pal=scicos_pal
  else
    scicos_pal=[]
  end
  path=pathconvert(path,%f,%t)
  if fileinfo(path)==[] then
    error('File: '+path+' do not exist')
  end
  if or(fileparts(path,'extension')==['.cos','.cosf']) then
    k=find(scicos_pal(:,1)==Title)
    if k==[] then
      scicos_pal=[scicos_pal;Title,path]
    else //## if a palette with same title exist
      k1=find(scicos_pal(k,2)==path)
      if k1==[] then //## not the same path
        indt=1;
        while (find(scicos_pal(:,1)==Title+' ('+string(indt)+')')<>[]) then
          indt=indt+1
        end
        kk=find(scicos_pal(:,1)==Title+' ('+string(indt-1)+')')
        kk1=find(scicos_pal(kk,2)==path)
        if kk1==[] then
          scicos_pal=[scicos_pal;Title+' ('+string(indt)+')',path]
        end
      end
    end
  else
    error('Second argument should be a path to a .cos or .cosf file.')
  end
endfunction
