Programming scicos blocks
fr - eng
block_type - Scicos block type
Contents
Module
Description
Scicos has the possibility to handle and to call many different sorts of blocks. Some blocks in Scicos palettes are special and are only used internally by Scicos, such as synchro blocks and the Debug block, but most blocks are regular blocks which the user can get inspired by to construct new blocks. The following table gives the known Scicos block types, and is followed by the report of the type of the computational function with its associated calling sequence by block type.
Type Description Function type Simulator call
-2 Event select block (synchro block). - Never called.
-1 If Then Else block (synchro block). - Never called.
0 C, Fortran or Scilab block. Calling sequence fixed. Obsolete. Type 0. Type 0.
1 C or Fortran block. Varying calling sequence. Obsolete. Type 1. Type 1.
2 C block. Calling sequence fixed. Obsolete. Type 2. Type 2.
3 Scilab block. Calling sequence fixed. Used but obsolete. Type 3. Type 2.
4 C block. Calling sequence fixed. In use. Type 4. Type 4.
5 Scilab block. Calling sequence fixed. In use. Type 5. Type 4.
1001 Fortran block. Dynamically linked. Obsolete. Type 1. Type 1.
2001 C block. Dynamically linked. Obsolete. Type 1. Type 1.
2004 C block. Dynamically linked. In use. Type 4. Type 4.
10001 Implicit C or Fortran block. Obsolete. Type 10001. Type 10001.
10002 Implicit C block. Obsolete. Type 10002. Type 10002.
10004 Implicit C block. In use. Type 10004. Type 4.
10005 Implicit Scilab block. In use. Type 10005. Type 4.
30004 Generic Modelica block. Dynamically linked. In use. Type 10004. Type 4.
99 Debug block. Type 5. Type 4.
Note that even if type 0, 1 and 2 are obsolete, they are still supported in Scicos; some blocks in the standard palettes of Scicos are still of these types. Block type 3 is still used by scifunc block (Scilab block) but users should prefer the type 5 when constructing a computational function in Scilab because it takes full advantage of new data structures. In fact it has all the the functionalities implemented for block type 4.
Authors
Alan Layec INRIA
