/** \file cmatview.c \author Benoit Bayol \version 1.0 \date September 2006 - January 2007 \brief CMATVIEW is a scope that connects a matrix to a grayplot. The values of the matrix are the values at the nodes \see CMATVIEW.sci in macros/scicos_blocks/Sinks/ */ #include "scoMemoryScope.h" #include "scoWindowScope.h" #include "scoMisc.h" #include "scoGetProperty.h" #include "scoSetProperty.h" #include "scicos_block4.h" #include <math.h> #include <stdlib.h> /** \fn cmatview_draw(scicos_block * block, ScopeMemory ** pScopeMemory, int firstdraw) \brief Function to draw or redraw the window */ void cmatview_draw(scicos_block * block, ScopeMemory ** pScopeMemory, int firstdraw) { int i; //As usual int * ipar; //Integer Parameters int win_pos[2]; //Position of the Window int win_dim[2]; //Dimension of the Window int dimension = 2; double * rpar; //Reals parameters double ymin, ymax; //Ymin and Ymax are vectors here double xmin, xmax; int number_of_curves_by_subwin; int number_of_subwin; double * mat; int size_mat; char *label; /*Retrieving Parameters*/ rpar = GetRparPtrs(block); ipar = GetIparPtrs(block); number_of_subwin = 1; win_pos[0] = -1; win_pos[1] = -1; win_dim[0] = -1; win_dim[1] = -1; size_mat = ipar[2]; mat = (double*)scicos_malloc(size_mat*sizeof(double)); for(i = 0 ; i < size_mat ; i++) { mat[i] = rpar[i+2]; } xmax = GetInPortSize(block,1,1); xmin = 0; ymax = GetInPortSize(block,1,2); ymin = 0; number_of_curves_by_subwin = 1; label = GetLabelPtrs(block); /*Allocating memory*/ if(firstdraw == 1) { scoInitScopeMemory(GetPtrWorkPtrs(block),pScopeMemory, number_of_subwin, &number_of_curves_by_subwin); } /*Creating the Scope*/ scoInitOfWindow(*pScopeMemory, dimension, -1, win_pos, win_dim, &xmin, &xmax, &ymin, &ymax, NULL, NULL); if(scoGetScopeActivation(*pScopeMemory) == 1) { sciSetColormap(scoGetPointerScopeWindow(*pScopeMemory), mat , size_mat/3, 3); scoAddTitlesScope(*pScopeMemory,label,"x","y",NULL); scoAddGrayplotForShortDraw(*pScopeMemory,0,0,GetInPortSize(block,1,1),GetInPortSize(block,1,2)); } scicos_free(mat); } /** \fn void cmatview(scicos_block * block, int flag) \brief the computational function \param block A pointer to a scicos_block \param flag An integer which indicates the state of the block (init, update, ending) */ void cmatview(scicos_block * block, int flag) { void **_work=GetPtrWorkPtrs(block); /* Declarations */ ScopeMemory * pScopeMemory; scoGraphicalObject pShortDraw; double * u1; double alpha,beta; int i,j; double * rpar; int dim_i, dim_j; int **user_data_ptr,*size_ptr; /* Initializations and Allocations*/ //Allocations are done here because there are dependent of some values presents below /* State Machine Control */ switch(flag) { case Initialization: { cmatview_draw(block,&pScopeMemory,1); break; } case StateUpdate: { /*Retreiving Scope in the _work*/ scoRetrieveScopeMemory(_work,&pScopeMemory); if(scoGetPointerScopeWindow(pScopeMemory) == NULL) return; if(scoGetScopeActivation(pScopeMemory) == 1) { pShortDraw = scoGetPointerShortDraw(pScopeMemory,0,0); rpar = GetRparPtrs(block); alpha = rpar[0]; beta = rpar[1]; u1 = GetInPortPtrs(block,1); dim_i = GetInPortRows(block,1); dim_j = GetInPortCols(block,1); for(i = 0 ; i < dim_i ; i++) { for(j = 0; j < dim_j ; j++) { pGRAYPLOT_FEATURE(pShortDraw)->pvecz[i*dim_j+j] = floor(alpha*u1[j+i*dim_j]+beta); } } sciSetUsedWindow(scoGetWindowID(pScopeMemory)); if(pFIGURE_FEATURE(scoGetPointerScopeWindow(pScopeMemory))->pixmap == 1) { C2F(dr)("xset","wshow",PI0,PI0,PI0,PI0,PI0,PI0,PD0,PD0,PD0,PD0,0L,0L); } sciDrawObj(scoGetPointerShortDraw(pScopeMemory,0,0)); } break; }//End of stateupdate case Ending: { scoRetrieveScopeMemory(_work, &pScopeMemory); if(scoGetScopeActivation(pScopeMemory) == 1) { if(scoGetPointerScopeWindow(pScopeMemory) != NULL) { sciSetUsedWindow(scoGetWindowID(pScopeMemory)); pShortDraw = sciGetCurrentFigure(); sciGetPointerToUserData (pShortDraw,&user_data_ptr, &size_ptr); FREE(*user_data_ptr); *user_data_ptr=NULL; *size_ptr = 0; } } scoFreeScopeMemory(_work, &pScopeMemory); break; } } }
