Scilab Function
fr - eng
create_palette - Palette generator
Module
Description
This function generates a palette if Path is a string indicating the directoy in which the interfacing functions of the blocks are to be found. If Path is not present or if it is %t, then standard scicos palettes are regenerated. If %f, then only IntFunc (list of interfacing functions) is returned. List of routines is empty in this case.
Calling Sequence
[routines,IntFunc] = create_palette(Path)
Parameters
File content
See Also
Authors
RN/AL INRIA
