builder - script scilab de construction de la boîte à outils
//builder.sce
//build modnum_3 package for scilab-3.0
//both linux and windob(with lcc)
//13-10-2004 Alan
//Modification : 4/4/2005
//builder rewritten with scilab function
//Improvment : Build with VC++
//Modif. : 13/09/2006
//routines building process reviewed.
//works now with ilib_for_link.
//rmk : building process no more supported
// for scilab-3.0,3.1
//Modif. : 14/04/2007
//review for windows compilation
// REVISION HISTORY :
// $Log$
//def_MODNUMSCI_path()
//Input : nothing
//Output : tt MODNUMSCI path (ex:/home/alan/modnum_3)
function tt=def_MODNUMSCI_path()
tt=get_absolute_file_path('builder.sce');
end_char=part(tt,length(tt));
if end_char=='/'|end_char=='\' then
tt=part(tt,1:length(tt)-1);
end
endfunction
//change mode, lines behavior and function protection
sav_mode=mode();
mode(-1);
sav_lines=lines();
sav_lines=sav_lines(2);
lines(0);
sav_prot=funcprot();
funcprot(0);
//define MODNUMSCI path
MODNUMSCI=def_MODNUMSCI_path();
clear def_MODNUMSCI_path;
tt_path='MODNUMSCI';
//Search Scilab Version
getf(MODNUMSCI+'/macros/build_util/find_scilab_ver.sci');
[ok]=find_scilab_ver();
if ~ok then
printf("modnum toolbox source version only build with ScicosLab >=4.3\n");
abort
end
//open loader.sce file for writting
ierror=execstr('u=mopen(MODNUMSCI+""/loader.sce"",""w"");','errcatch');
if ierror<>0 then
printf("Can''t write loader file.\nVerify your writting access.\n");
end
clear ierror;
//write Header of loader.sce file
getf(MODNUMSCI+'/macros/build_util/write_header.sci');
txt=write_header(u,'builer.sce',tt_path);
ierr=execstr(txt,'errcatch');
//Build and load util macro library
getf(MODNUMSCI+'/macros/build_util/build_lib.sci');
build_lib('/macros/build_util','modnum_build_util',tt_path);
getf(MODNUMSCI+'/macros/build_util/write_inf_lib.sci');
txt=write_inf_lib(u,'/macros/build_util','modnum_build_util',1,tt_path);
//Build and load all scilab library
libs = ['find_file';
'misc';
'pll';
'signal'];
rep_lib = '/macros/'+libs;
lib_name = 'modnum_'+libs;
build_lib(rep_lib,lib_name);
txt = write_inf_lib(u,rep_lib,lib_name,1,tt_path);
ierr = execstr(txt,'errcatch');
//Build routines Library
printf("Build modnum routines libraries\n");
//Build and load modnum_lib routines
printf("Build modnum_lib C routines\n");
path='/../../src';
files=basename(listfiles(MODNUMSCI+path+'/*.c'));
libnam="modnum_lib";
cflag="-DWITH_SCIFFT=1";
//update path of MODNUMSCI for ilib_for_link
MODNUMSCI_path=MODNUMSCI;
if MSDOS then
MODNUMSCI_path=strsubst(MODNUMSCI,'\','\\');
end
//Build modnum_lib
rep=pwd();
if ~exists('Id_libmodnum_lib') then
chdir(MODNUMSCI+path);
ierr=execstr('ilib_for_link(files,files+''.o'',[],""c"",""Makelib"",""loader.sce"",libnam,"""",cflag);','errcatch')
chdir(rep);
if ierr<>0 then
printf("\n Error during compilation inside scilab.\n"+...
" Building process of modnum aborted.\n");
mclose(u);
clear files, clear libnam; clear scifunc; clear intname;
abort;
end
end
txt=write_inf_rout_lib(u,'lib'+libnam,path,files,0,tt_path);
//Build and load scilab interface of modnum_lib routines
printf("Build Scilab interface of modnum_lib\n");
path='/gateway';
libnam="intmodnum_lib";
//set CFLAGS
if MSDOS then
cflag="-I"""+MODNUMSCI_path+"\\..\\..\\src"" -c";
else
cflag="-I"""+MODNUMSCI_path+"/../../src"" -c";
end
//set LDFLAGS
if MSDOS then
if fileinfo(MODNUMSCI+'/../../src/libmodnum_lib.ilib')<>[] then
ldflag=" """+MODNUMSCI_path+"\\..\\..\\src\\libmodnum_lib.ilib"""
else
ldflag=" """+MODNUMSCI_path+"\\..\\..\\src\\libmodnum_lib.lib"""
end
else
ldflag=""
end
//Build modnum_lib
rep=pwd();
ierr=execstr('ilib_for_link(files,files+''.o'',[],""c"",""Makelib"",""loader.sce"",libnam,ldflag,cflag);','errcatch')
chdir(rep);
if ierr<>0 then
mclose(u);
abort;
end
//Define interfacing function
scifunc=["autocorr";"awgn";
"demodpsk";"demodqam";"despread";"downsmpl";
"gengold";"genint";"genpn";"genrayl";
"intsym";
"modpsk";"modqam";
"nfilter";
"spread";
"upsmpl"];
intname="intmodnum_lib";
txt=write_addinter_line(u,'lib'+libnam,path,intname,scifunc);
clear MODNUMSCI_path;
clear files_c; clear libnam; clear rep;
clear path; clear ierr; clear cflag;
clear ldflag;clear i;
//Build documentation and demos
tt_help='myhelps=[MODNUMSCI+''/help/''+lang+''/htm'',...
""Modnum communication toolbox (Scilab)""];';
tt_demos=['add_demo(''Modnum (Scilab)'',...
MODNUMSCI+''/demos/modnumsci.dem'');'];
txt=write_inf_doc(u,tt_path,tt_help,tt_demos);
//flag_doc=build_doc();
//Close loader.sce
mclose(u);
printf("Write a loader.sce file\n");
//write a .scilab file
if ~MSDOS then
txt=mgetl(MODNUMSCI+'/loader.sce');
mputl(txt,MODNUMSCI+'/.scilab');
printf("Write a .scilab file\n");
end
clear u; clear txt; clear ierr; clear ok;
clear tt_help; clear tt_demos;clear tt_path;
//retrieve original mode, lines behavior and function protection
mode(sav_mode);
lines(sav_lines);
funcprot(sav_prot);
clear sav_mode; clear sav_lines; clear sav_prot;
IRCOM Group Alan Layec
