Next: 1.13 DS NOPO
Up: 1 Description of DS by type
Prev: 1.11 DS MUA
Index
Contents
This DS describes the degree of freedom numbers corresponding to each node. At the modules level, this information is exploited through function NDL:
NDL(i+1) is the number of the last degree corresponding to node i.
DS NDL1 is different to the other DS. There are three cases possible:
0, i.e. the number of degrees of freedom per node is constant; we thus have:
In practice, DS NDL1 only exists in cases 2 and 3. In order for its existence to be transparent
to the user, it is coupled with function LRNDL1. All modules using DS
NDL1, needs to, before calling NDL, initialize the process by
[4]
DS NDL1 is created using a DS MAIL by module CONDL1.
SUBROUTINE CONDL1(M,NNSEG,NFMAIL,NIMAIL,NFNDL1,NINDL1,
+ LNOET,NNOMAX,ND,NDLMAX)
C AIM : CONSTRUCT A DS NDL1
