![[BIG]](../icons/zoom18.gif)
![[Normal]](../icons/zoom14.gif)
![[small]](../icons/zoom10.gif)
Next: 4.6 CSAMAT
Up: 4 Utilities
Prev: 4.4 CCMUA
Contents
- Aim:
- Construct a D.S. NDL1 from a D.S. MAIL. The algorithms described in this guide call
function NDL, which assigns the number of the last degree of freedom associated with
node I to NDL(I+1) (using the convention NDL(1)=0).
to initialize this function, the module calls function LRNDL1, and then:
- if the number of degrees of freedom at each node ND is constant, NDL(I+1) = I * ND
- if not, NDL(I+1) = the number of the last degree of freedom associated with node I, and is read into NDL1.
See section 1.2.9.
Next: 4.6 CSAMAT
Up: 4 Utilities
Prev: 4.4 CCMUA
Contents
