Next: 4.7 ELVOIS
Up: 4 Utilities
Prev: 4.5 CONDL1
Contents
This procedure enables us to compute a preconditioning matrix efficiently, but necessitates the assembly of matrix A in skyline form in secondary memory. This technique is interesting when numerous linear systems need to be solved using the same matrix. To use this module, please consult section 2.1.6.
