Next: 8.2 Adapting a new output terminal
Up: 8 Adapting a new terminal
Prev: 8 Adapting a new terminal
Contents
The link between FORTRAN 3D and the input terminals is made through two intermediary subroutines PERFGN and ITRCTG.
Subroutine PERFGN will be defined in the next section. Subroutine ITRCTG is constructed as follows:
ITRCTG :
SUBROUTINE ITRCTG(INSTRU, T1, T2, T3, IT1, IT2, IT3, STRING)
CHARACTER *(*)STRING
REAL T1(*), T2(*), T3(*)
INTEGER IT1(*), IT2(*), IT3(*)
include 'data_f3d.ins'
GOTO(1 , 2, 3, 4, 5, 6, 7, 8, 9, 10 , 11), IDEVIN
C
CALL ITRCTX(INSTRU, T1, T2, T3, IT1, IT2, IT3, STRING)
RETURN
001 CONTINUE
C APOLLO
CALL ITRCT5(INSTRU, T1, T2, T3, IT1, IT2, IT3, STRING)
RETURN
002 CONTINUE
C LASER_WRITER(POST_SCRIPT)
RETURN
003 CONTINUE
C X_WINDOW_V11
CALL ITRCTX11(INSTRU, T1, T2, T3, IT1, IT2, IT3, STRING)
RETURN
004 CONTINUE
C TEKTRONIX_4014
CALL ITRCT1(INSTRU, T1, T2, T3, IT1, IT2, IT3, STRING)
RETURN
005 CONTINUE
C APOLLO_5
RETURN
006 CONTINUE
C PRINTER
RETURN
007 CONTINUE
C VERSATEK_SPECTRUM_V80
RETURN
008 CONTINUE
C VERSATEK_V80
RETURN
009 CONTINUE
C TEKTRONIX_4107
CALL ITRCTE(INSTRU, T1, T2, T3, IT1, IT2, IT3, STRING)
RETURN
010 CONTINUE
C TEKTRO_4105
CALL ITRCTN(INSTRU, T1, T2, T3, IT1, IT2, IT3, STRING)
RETURN
011 CONTINUE
C PHIGS
CALL ITRPHG(INSTRU, T1, T2, T3, IT1, IT2, IT3, STRING)
RETURN
END
For an arbitrary driver, the parameters are:
The use of these variables depends on INSTRU (see below).
To use a graphics terminal, which is not yet offered on the MODULEF magnetic tape, the user needs to write program ITRCT* (see below) and include a call to subroutine ITRCTG in it.
Parameter INSTRU has very particular effects if it is negative:
if(INSTRU.lt.0)then {interrogation du device}
if( INSTRU.eq.-1)then
c print on i1= number of order
call wchari(i1, 'PERIPHERIQUE XXX en entree')
return
elseif(INSTRU.eq.-2)then
c definition of the call parameters with dialogue
c we assign, using dialogue, the call parameters
c that we store in IT2(1), IT2(2), ... STRING
return
elseif(INSTRU.eq.-3)then
c default parameters (without dialogue)
IT2(1)=std { type standard du curseur }
return
endif
endif
call wchari(INSTRU, ' est une valeur incomprehensible en entree')
return
GOTO indexe selon les valeurs >0 de INSTRU
goto(1, 2, 3, 4, 5, 6, 7, 8, 9), INSTRU
The different tasks to be performed, referenced by INSTRU, are described below:
INSTRU = 1 : INITIALIZATIONS OF THE INPUT TERMINAL (DEVICI)
IN : IT1 : number of the active terminal
IT2(*) and STRING : supplementary information for
certain terminals
Initialize the values of the keys whose names are in
key_board.ins
c key values for APOLLO
bs=char(8)
cr=char(13)
lf=char(10)
del=char(127)
mark=char(129)
line_del=char(130)
char_del=char(131)
marg_left=char(132)
cmd=char(133)
marg_right=char(134)
pad_left=char(135)
curs_down=char(136)
pad_right=char(137)
curs_left=char(138)
next_window=char(139)
curs_right=char(140)
pad_up=char(141)
curs_up=char(142)
pad_down=char(143)
pop=char(144)
again=char(145)
exit=char(148)
back_space=char(149)
return=char(150)
funct1=char(192)
funct2=char(193)
funct3=char(194)
funct4=char(195)
funct5=char(196)
funct6=char(197)
funct7=char(198)
funct8=char(199)
funct9=char(187)
funct10=char(0)
funct11=char(0)
funct12=char(0)
shell=char(205)
copy=char(232)
tpast=char(233)
grow=char(234)
hold=char(235)
cut=char(236)
undo=char(237)
move=char(238)
help=char(239)
c with shift
funct0=char(186)
sfunct0=char(190)
sfunct1=char(208)
sfunct2=char(209)
sfunct3=char(210)
sfunct4=char(211)
sfunct5=char(212)
sfunct6=char(213)
sfunct7=char(214)
sfunct8=char(215)
sfunct9=char(191)
sfunct10=char(0)
sfunct11=char(0)
sfunct12=char(0)
smarg_right=char(206)
spad_left=char(207)
scurs_down=char(216)
spad_right=char(217)
scurs_left=char(218)
snext_window=char(219)
scurs_right=char(220)
spad_up=char(221)
scurs_up=char(222)
spad_down=char(219)
sagain=char(181)
sread=char(182)
spop=char(200)
INSTRU = 2 : INPUT A POSITION (GETXY)
OUT : T1(1) : X in cm.
T2(1) : Y in cm.
INSTRU = 3 : INPUT A POSITION AND ENTER A CHARACTER (GETXYC)
T2(1) : Y in cm.
STRING(1:1) the character entered
INSTRU = 4 : INPUT A BROKEN LINE (STROKE)
IN : IT1(1) number of points to input
IT1(2) constraint
0 : no constraint
1 : 2 successive points on the curve input
are separated by a minimum of T3(1) cm. and
a maximum of T3(2) cm.
OUT : IT2(1) number of points actually input
T1(*) : array containing the abscissas in cm.
T2(*) : array containing the coordinates in cm.
INSTRU = 5 : INPUT A TEXT (GETEXT)
IN : T1(1) : X in cm. of the beginning of the text
T2(1) : Y in cm. of the beginning of the text
STRING(1:IT1(1)) : the non-editable text to print
IT1(1) : number of characters in the non-editable text
to print
IT2(1) : maximum number of characters
IT3(1) : number of characters in the initial editable text
STRING(IT1(1)+1:IT1(1)+IT3(1)) : initial editable text
OUT : T3(1) : X in cm. of the end of the text
T3(2) : Y in cm. of the end of the text
IT3(1) : number of characters input
STRING(IT1(1)+1 : IT1(1)+IT3(1)) : text input
INSTRU = 6 : INPUT A NUMBER (GETNUM)
STRING(1:IT1(1)) : the text to print
IT1(1) : number of characters in the text to print
IT2(1) : type of number (0 integer, 1 real, 2 boolean)
IT2(2) : constraint
0 : no constraint
1 : min and max constraints for the numbers:
the constraints are stored in:
T3(1)=min and T3(2)=max for reals
IT3(1)=min and IT3(2)=max for integers
OUT : depending on type:
IT3(3) the integer or boolean (0=.TRUE., 1=.FALSE.) number
T3(3) the real number
If the user types (return) the variables are not modified on exit.
INSTRU = 7 : INPUT AN IDENTIFICATION (GETHIT)
OUT : IT1(1) : number of the designated segment
IT1(2) : associated value
( value given by debas(*) if not -1 )
INSTRU = 8 : DIMENSION OF THE INPUT SURFACE (SZSCRI)
OUT : T1(1) : Xmin in cm.
T1(2) : Xmax in cm.
T1(3) : Ymin in cm.
T1(4) : Ymax in cm.
INSTRU = 9 : INQUIRY OF THE NUMBER OF MOUSE KEYS (INQCRC)
OUT : IT1(1) : number of keys on the mouse
IT2(*) : the integer codes of the keys or 0 if undefined code
Inspired by the programs already proposed, we define the different actions as a function of the possibilities offered by the graphics terminal at our disposal.
The fictitious subroutine, ITREXE, residing in library perf-example can serve as a model when creating the input program for a new device.
In addition, a certain number of subroutines were written to aid with a quick implementation of the drivers (see chapter 7 and the index):
GETUNF RCHARS RINTG
RREAL CHARI WCHARS
ZCENTR ZCOLOR ZFNDTC
ZGNUM ZGTEXT ZSTROK
ZTXT
