Next: 8.3 List of devices available
Up: 8 Adapting a new terminal
Prev: 8.1 Adapting a new input terminal
Contents
The link between FORTRAN 3D and the output terminals is made by two intermediary subroutines, PERFGN and ITRCTG.
Subroutine ITRCTG was presented in the previous section. Subroutine PERFGN serves as interface between the graphics software, FORTRAN 3D, and your basic device.
PERFGN :
SUBROUTINE PERFGN(INSTRU, V1, V2, V3, I1, I2, I3, ICH, STRING)
CHARACTER *(*)STRING
REAL V1(*), V2(*), V3(*)
INTEGER ICH(*)
include 'data_f3d.ins'
GOTO(1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11), IDEVIC
C IF IDEVIC=0 ASSIGN THE NUMBER OF DEVICES TO ICH(1)
IF(IDEVIC.EQ.0)THEN
C ICH(1) = NUMBER OF DEVICES AVAILABLE
ICH(1)=11
RETURN
ENDIF
CALL PERIFX(INSTRU, V1, V2, V3, I1, I2, I3, ICH, STRING)
RETURN
001 CONTINUE
C APOLLO
CALL PERIF5(INSTRU, V1, V2, V3, I1, I2, I3, ICH, STRING)
RETURN
002 CONTINUE
C LASER_WRITER(POST_SCRIPT)
CALL PERIFD(INSTRU, V1, V2, V3, I1, I2, I3, ICH, STRING)
RETURN
003 CONTINUE
C X_WINDOW_V11
CALL PERIFX11(INSTRU, V1, V2, V3, I1, I2, I3, ICH, STRING)
RETURN
004 CONTINUE
C TEKTRONIX_4014
CALL PERIF1(INSTRU, V1, V2, V3, I1, I2, I3, ICH, STRING)
RETURN
005 CONTINUE
C APOLLO_5
RETURN
006 CONTINUE
C PRINTER
CALL PERIF7(INSTRU, V1, V2, V3, I1, I2, I3, ICH, STRING)
RETURN
007 CONTINUE
C VERSATEK_SPECTRUM_V80
CALL PERIF8(INSTRU, V1, V2, V3, I1, I2, I3, ICH, STRING)
RETURN
008 CONTINUE
C VERSATEK_V80
CALL PERIFC(INSTRU, V1, V2, V3, I1, I2, I3, ICH, STRING)
RETURN
009 CONTINUE
C TEKTRONIX_4107
CALL PERIFE(INSTRU, V1, V2, V3, I1, I2, I3, ICH, STRING)
RETURN
010 CONTINUE
C TEKTRO_4105
CALL PERIFN(INSTRU, V1, V2, V3, I1, I2, I3, ICH, STRING)
RETURN
011 CONTINUE
C PHIGS
CALL PERPHG(INSTRU, V1, V2, V3, I1, I2, I3, ICH, STRING)
RETURN
END
For an arbitrary driver, the parameters are:
The utilization of these variables depends on INSTRU (see below).
To use a graphics terminal, which is not yet supplied on the MODULEF magnetic tape, the user needs to write program PERIF* (see below) and include a call to subroutine PERFGN in it.
Parameter INSTRU has very particular effects if it is negative:
if(INSTRU.lt.0)then {interrogation du device}
if( INSTRU.eq.-1)then
c print on i1= number of order
call wchari(i1, 'PERIPHERIQUE XXX')
return
elseif(INSTRU.eq.-2)then
c definition of the call parameters with dialogue
c we assign, using dialogue, the call parameters
c that we store in ICH(1), ICH(2), ... STRING
return
elseif(INSTRU.eq.-3)then
c default parameters (without dialogue)
ICH(1)=std { affichage standard : plein ecran }
ICH(2)=2 { couleur du fond}
STRING='blabla'
return
endif
endif
call wchari(INSTRU, ' est une valeur incomprehensible')
return
GOTO indexe selon les valeurs >0 de INSTRU
goto(1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,
+ 23,24,25,26,27,28,29,30,31,32,33,34,35), INSTRU
The different tasks to be performed, referenced by INSTRU, are described below:
INSTRU = 1 : INITIALIZATION OF THE TERMINAL (DEVICE)
IN : I1 : number of the active terminal
ICH(*) and STRING : supplementary information
for certain terminals
All variables used are initialized by default
(for example: line type, text size, ...).
INSTRU = 2 : DEFINITION OF THE GRAPHIC CHARACTERISTICS (LIGH3)
IN : I1 : intensity (if >= 0 assign)
I2 : blinking (0 no, 1 yes) (if >= 0 assign)
if stereo ( right=4 / left=2 )
I3 : color number in the color table
(if >= 0 assign)
INSTRU = 3 : DEFINITION OF LINES (DRAW3)
IN : I1 : line type (full, dotted ...)
define : type = I1
if I1 < 0 no lines plotted
V1(1) : line thickness in mm. (if >= 0 assign)
INSTRU = 4 : PLOT A LINE SEGMENT (LIN2TO, LIN3TO, ...)
IN : V1(1) : abscissa of the beginning of the segment
V1(2) : ordinate of the beginning of the segment
V2(1) : abscissa of the end of the segment
V2(2) : ordinate of the end of the segment
if type < 0 no plot
INSTRU = 5 : PLOT TEXT (TXT2D, TXT3D, ...)
IN : I1 : number of characters in the text
V1(1) : abscissa of the beginning of the text
V1(2) : ordinate of the beginning of the text
STRING : the text
if type < 0 no plot
if I1 = 1 and STRING(1:1) has a set
of centerable characters ( O o X x + * 0 ) center
the character.
INSTRU = 6 : START OF A DESIGNATED ZONE (DEBAS)
IN : I1 : zone identifier
INSTRU = 7 : END OF DESIGNATED ZONE (FINAS)
INSTRU = 8 : TEXT PLOT CHARACTERISTICS (DRW3TX)
IN : I1 : number of the character font available
i1=0 look for the font with the size
closest to that chosen
i1#0 use font i1
V1(1) : character size in cm.
V2(1) : text angle w.r.t. the horizontal
(as a fraction of pi/2.)
INSTRU = 9 : START OF A FACET (DEBFAC)
IN : I1 : = 0 : external contour, 1 hole
INSTRU = 10 : END OF FACET (FINFAC)
plot the facet
INSTRU = 11 : CLEAR SCREEN (CLEAN)
all existing plots are deleted
INSTRU = 12 : DISPLAY OF A SEGMENT. HIGHLIGHT (DSPLAY, HIGHLT)
I1 : 0 = normal display
1 = highlight (blinking ...)
ICH(1) = segment number
INSTRU = 13 : OPENING A SEGMENT (OPENG)
a segment represents a sequence of graphical
instructions defined between openg and closeg.
INSTRU = 14 : CLOSING A SEGMENT (CLOSEG)
INSTRU = 15 : KILL A SEGMENT (KILL)
INSTRU = 16 : REMOVE A SEGMENT (REMOVG)
INSTRU = 17 : INQUIRE SCREEN SIZE (SZSCRN)
OUT : V1(1) = abscissa of the lower left-hand corner in cm.
V1(2) = its ordinate in cm.
V1(3) = abscissa of the upper right-hand corner in cm.
V1(4) = its ordinate in cm.
The screen is thus defined in cm.
INSTRU = 18 : INQUIRE IF SEGMENT EXISTS (INQEXS)
IN : ICH(1)= segment number
OUT : I2= 0 if the segment exists, 1 if not
INSTRU = 19 : LIST OF EXISTING SEGMENTS (INQNXS)
IN : I1 = 1 initialization of the search
I1 = 0 request next segment number
OUT : if I1 = 0
I2 = 0 if there is a next segment
ICH(1) number of this segment
I2 -= 0 if there is no segment following
INSTRU = 20 : UPDATE SCREEN (UPDATE)
INSTRU = 21 : END, CLOSE DEVICE (ENDDEV)
IN : I1 : terminal number
INSTRU = 22 : GO TO STEREO MODE (STEREO)
IN: I1=1 (on) I1=0 (off)
OUT: I2 =0 stereo
I2-=0 no stereo
INSTRU = 23 : CURRENT COLOR (INQCOL)
OUT : V1(1), V2(1), V3(1) reals between 0. and 1. giving R G B
(proportion of Red, Green, Blue)
INSTRU = 24 : SET CURRENT COLOR (SETCOL)
IN : set the current color equal to the value in the array
closest to (V1(1), V2(1), V3(1)
INSTRU = 25 : NUMBER OF COLORS (INBCOL)
OUT : I1 : number of colors possible
(background color and at least the other : I1 >= 2)
INSTRU = 26 : DEFINE THE COLOR ARRAY (SETTBC)
IN : Set V1(1:), V2(1:), V3(1:) [0...1] in the color array
between indices I1 and I2 inclusive.
Indices I1 and I2 varies from 0 to nbcolo-1.
OUT : I3 = 0 assignment performed
I3 = -1 table not modifiable
INSTRU = 27 : NUMBER OF COLORS AND ARRAY (INQTBC)
OUT : returns in V1(1:), V2(1:), V3(1:) [0...1]
the current color array between the indices I1 and
I2 inclusive.
INSTRU = 28 : HARD CLIP FOR TEXT (CLIPHD)
IN : V1(1) min in x of the zone, in cm.
V1(2) max in x
V1(3) min in y
V1(4) max in y
I1 = 1 clip, 0 if not
INSTRU = 29 : SELECTIVE DELETION (INQFAC)
OUT : I1 : 0 if selective deletion is possible, 1 if not
INSTRU = 30 : EXISTENCE OF INPUT (INQCUR)
OUT : I1 : 0 if there is input at the cursor (or other),
1 if not
If there is input we keep the same terminal number
(see ITRCTG : adapting to a new input terminal)
INSTRU = 31 : MAXIMUM TEXT QUALITY (INQMQT)
OUT : I1 =0 if the maximum text quality is HARD
(le text soft est plus mauvais que le hard)
=1 if the maximum text quality is SOFT
INSTRU = 32 : TEXT CENTERING (CTRTXT)
IN : V1(1) = alpha position in a box (0., 0.) (1., 1.)
V1(2) = beta of the center of the text in x (alpha)
and y (beta) : alpha and beta between 0. et 1.
By default alpha = beta = 0.
INSTRU = 33 : INQUIRE MAXIMUM NUMBER OF SEGMENTS MANAGED (INQSGM)
OUT : I1 = maximum number of segments managed (0 = none)
if i1 >0 this signifies that ALL instructions are managed correctly:
12 DSPLAY
13 OPENG
14 CLOSEG
15 KILL
16 REMOVG
18 INQEXS
19 INQNXS
INSTRU = 34 : RETURN THE NUMBER OF THE CURRENT COLOR (INQNCO)
OUT : I1 = number of current color
INSTRU = 35 : hardcopy (HARDCP)
IN: I1 = choix1 (if different hardcopy terminals)
I2 = choix2 (if different material possibilities)
Inspired by the programs already proposed, we define the different actions as a function of the possibilities offered by the graphics terminal at our disposal.
The fictitious subroutine, PEREXE, residing in library perf-example can serve as a model when creating the output program for a new device.
In addition, a certain number of subroutines were written to aid with a quick implementation of the drivers (see chapter 7 and the index):
GETUNF RCHARS RINTG
RREAL CHARI WCHARS
ZCENTR ZCOLOR ZFNDTC
ZGNUM ZGTEXT ZSTROK
ZTXT
