Modulefpreviousupnextcontents[BIG][Normal][small]
Next: 2 Installation procedure: UNIX Up: 1 Introduction Prev: 1 Introduction Contents
1.1 Minimal configuration:
In addition, the MODULEF system requires a Fortran 77 compiler with the following two extensions:
MODULEF runs successfully on a number of computers, such as CRAY, HP/Apollo, IBM RS 6000, SUN, Silicon, HP 9700, Dec Alpha OSF/1 etc.
