Modulefpreviousupnextcontents[BIG][Normal][small]
Next: 2.1 The installation procedure: Up: Part III: Installation Prev: 1.1 Minimal configuration: Contents
2 Installation procedure: UNIX
The principal instructions to follow when installing MODULEF on a UNIX machine are given in the Quick Reference at the beginning of Part iii. This chapter gives a detailed description of the installation procedure in sections 2.1 and 2.2 and the MODULEF structure in section 2.3.
Note:
