Modulefpreviousupnextcontents[BIG][Normal][small]
Next: 5.1 Installation of the commands Up: 5 Management under UNIX Prev: 5 Management under UNIX Contents
Foreword
The aim of this chapter is to describe the MODULEF library management tools for UNIX machines. These commends are used to manage the library, but also to facilitate the readers own developments around MODULEF (compilation commands, linking, ... ).
In the sections which follow, the following points are investigated: installation, utilization and description of the commands.
