Next: 3.3 Test 6: Fluid Mechanics Problem
Up: 3 Batch tests
Prev: 3.1 Test 4: Thermal Problem
Contents
Calculate the displacements and stresses of a clamped beam subject to a vertical traction at its extreme.
Figure 3.4: Two-dimensional elasticity problem
The beam problem is a two-dimensional elasticity problem with plane deformation. We consider a homogeneous isotropic material.
Remark: It is favorable that the nodes at corners (20, -2) and (20, 2) on
belong to two elements, due to discontinuities. For example, on the boundary
Find the displacement
in
and
which satisfies:
where
Assume that
The exact solution is not known.
The type of finite element utilized in order to solve this problem: TRIA 2P2D (P2 Lagrange triangle)
Step 1: Mesh
| Execute program: | D5NOXX | |
| Modules used: | APNOPO | ... 2D mesh generator [MODULEF User Guide - 3] |
| CONOPO | ... manual mesh generator | |
| MODNOP | ... translation | |
| RETRIN | ... subdivision of mesh | |
| RECOLC | ... 'glue together' of meshes | |
| ADPNOP | ... addition of nodes | |
| GIBBS | ... renumbering of nodes | |
| Libraries: | NOP2, NOPO, UTSD, UTII | |
| Input data file: | D5NOPO.D | |
| Output data structure: | T5NOPO | |
Step2: Interpolation [13]
| Execute program: | D5COXX |
| Module used: | COMACO [13] |
| Libraries: | ELAS, COSD, UTSD, UTII |
| Element type: | TRIA 2P2D |
| Output data structures: | T5MAIL |
| T5COOR |
Step 3: Calculation of the element arrays and description of boundary conditions
| Execute program: | D5CAXX | |
| Modules used: | ELASCT | ... calculates element arrays for the constant case [14] |
| CONDL1 | ... construction of numbers of the degrees of freedom associated with each node [20] | |
| COBDC1 | ... introduction of boundary conditions [18] | |
| Libraries: | COSD, ELAS, ELA2, UTII, UTSD | |
| Output data structures: | T5TAE | |
| T5BDCL |
Step 4: Solution
| Execute program: | D5REXX | ... solution by a Crout direct method after assembly of the matrix and RHS vector and incorporation of boundary conditions [MODULEF User Guide - 5] |
| Modules used: | PREPAC | ... allocation of pointers |
| ASSMUA | ... assembly of matrix in main memory (m.m.) | |
| ASEMBV | ... assembly of RHS vector in m.m. | |
| CLIMPC | ... introduction of boundary conditions | |
| CROUPC | ... factorization by Crout | |
| DRCRPC | ... forward and backward substitution | |
| Libraries: | RESB, RESO, RESD, UTSD, UTII | |
| Output data structure: | T5B | |
The number of words necessary to store the matrix in main memory is 38 127.
The number of words necessary to store the corresponding right-hand-side (RHS) vector is 1377.
Step 5: Calculation of stresses [90]
| Execute program: | D5STXX |
| Modules: | STRESS [90] |
| Output data structure: | T5TAES |
The table below represents the approximate maximum values of memory usage and execution time.
| Step | Dimension of | Execution time |
| the super array LM | (DPS8 Multics) | |
| Mesh | 15 000 | 23.0 |
| Interpolation | 8 000 | 3.5 |
| Element arrays | 8 000 | 12.7 |
| Solution | 45 000 | 25.0 |
| Stresses | 6 000 | 7.0 |
The super array M is dimensioned to 45 000 words in all the programs.
The output of the D.S. B, containing the displacements at all the nodes in the mesh, is found in the file S5B.D in library TESD. The stress values of the first 45 elements are found in file S5TAES.D in library TESD.
The remainder of this section contains the partial or total printout of the various D.S. created by the different programs. These data structures can be viewed by calling preprocessor IMAGXX and specifying the names of the files containing the desired data structures.
PRINT OUT OF D.S. NOPO OF LEVEL 0
TITLE : BENCHMARK MODULEF NUMBER 5 :PLANE DEFORMATION-STRESS
DATE AND USER'S NAME : 29/10/90 dutoit
DATA STRUCTURE TYPE : NOPO
LEVEL AND STATE NUMBER : 0 0
NUMBER OF ASSOCIATED TABLES : 0
TABLE N O P 2
CHARACTERISTICS OF THE MESH :
SPACE DIMENSION (NDIM ) : 2
MAXIMUM NUMBER OF REFERENCES (NDSR ) : 3
MAXIMUM NUMBER OF SUB-DOMAINS (NDSD ) : 1
NODES AND POINTS DO NOT COINCIDE (NCOPNP) : 0
NUMBER OF ELEMENTS (NE ) : 144
NUMBER OF TRIANGLES (NTRI ) : 144
NUMBER OF BOUNDARY ELEMENTS (NEF ) : 88
NUMBER OF NODES (NOE ) : 333
NUMBER OF NODES BY SEGMENT (NO EXTREMITIES) : 1
NUMBER OF POINTS (NP ) : 95
TYPE OF COORDINATE VALUES (NTYCOO) : REEL1MOT
MAX DIFFERENCE +1 BETWEEN 2 NODES OF AN ELEMENT : 26
NUMBER OF COARSE ELEMENTS (NBEGM ) : 0
NUMBER OF WORDS FOR TABLE NOP5 (LNOP5 ) : 2468
REFERENCE AXIS X,Y,Z (NTACOO) : 1
TABLE N O P 4
COORDINATES OF POINTS
| POINT | X | Y | | POINT | X | Y |
| 1 | 8.88888 | 0.000000 | | 2 | 10.0000 | 0.000000 |
| 3 | 8.88888 | 1.00000 | | 4 | 10.0000 | 1.00000 |
| 5 | 8.88888 | 2.00000 | | 6 | 10.0000 | 2.00000 |
| 7 | 4.44440 | 0.000000 | | 8 | 6.66662 | 0.000000 |
| 9 | 4.44440 | 2.00000 | | 10 | 6.66662 | 2.00000 |
TABLE N O P 5
DESCRIPTION OF ELEMENTS
| ELEMENT : 1 | TRIANGLE | S-D : 1 | NUMBER OF STORED WORDS : 0
NUMBER OF NODES : 6 : 152 176 154 163 164 153
NUMBER OF POINTS : 3 : 1 2 3
| ELEMENT : 2 | TRIANGLE | S-D : 1 | NUMBER OF STORED WORDS : 0
NUMBER OF NODES : 6 : 176 178 154 177 166 164
NUMBER OF POINTS : 3 : 2 4 3
PRINT OUT OF D.S. MAIL OF LEVEL 1
TITLE :
DATE AND USER'S NAME : 13/09/90 dutoit
DATA STRUCTURE TYPE : MAIL
LEVEL AND STATE NUMBER : 1 0
TABLE M A I 2
SPACE DIMENSION (NDIM) : 2
NUMBER OF UNKNOWNS OF THE VARIATIONAL FORMULATION (NINCFV) : 2
NUMBER OF TYPES OF ELEMENTS (NTYELM) : 1
NUMBER OF REFERENCES (NNR) : 3
NUMBER OF TYPES OF NODES (NTYNOE) : 1
NUMBER OF TYPES OF POINTS (NTYPOI) : 1
NUMBER OF WORDS OF TABLE MAI3 (LMAI3) : 36
POINTS ARE ONLY DEFINED BY THEIR COORDINATES
MAX NUMBER OF WORDS FOR AN ELEMENT (NMMAEL) : 25
NUMBER OF WORDS OF THE TABLE MAIL (LMAIL) : 2756
STORAGE OPTION (NOPFI) : 0
TABLE M A I 3
NUMBER OF ELEMENTS (NE) : 144
NUMBER OF NODES (NOE) : 333
NUMBER OF POINTS (NP) : 95
NUMBER OF SUB-DOMAINS (NDSD) : 1
*** TABLE OF THE TYPES OF ELEMENTS ***
| S-D | NODE | SEGMENT | TRIANGLE | QUADRANGLE |
| | STRAIGHT CURVED | STRAIGHT CURVED | STRAIGHT CURVED | STRAIGHT CURVED |
| 1 | | | | |TRIA2P2D| | | |
| S-D | TETRAHEDRON | PENTAHEDRON | HEXAHEDRON | SUPER-ELEMENT |
| 1 | | | | | | | | |
TABLES M A I 5 TO M A I 8
DESCRIPTION OF NODE TYPES
NUMBER OF VARIATIONAL UNKNOWNS FOR EACH NODE TYPE
TYPE 1 : 2
NODE TYPE 1 :
DEPLACEMENT EN X (UNKNOWN : 1) : VN
DEPLACEMENT EN Y (UNKNOWN : 2) : VN
TABLES M A I B TO M A I K
DESCRIPTION OF ELEMENT TYPES
ELEMENT TYPE 1 :
ELEMENT NAME : ELASTRIA2P2D
ELEMENT CODE : 200002
THE ELEMENT IS A : TRIANGLE
NUMBER OF NODES : 6
NUMBER OF ASSOCIATED TABLES : 1
| NODE | TYPE | COORDINATES ON THE UNIT ELEMENT |
| 1 | 1 | 0.0000000 0.0000000
| 2 | 1 | 1.000000 0.0000000
| 3 | 1 | 0.0000000 1.000000
| 4 | 1 | 0.5000000 0.0000000
| 5 | 1 | 0.5000000 0.5000000
| 6 | 1 | 0.0000000 0.5000000
| POINT | TYPE | COORDINATES ON THE UNIT ELEMENT |
TABLE 1 ( TYPE ENTIER ) : 1 MAX VALUE OF INDEX(ES) : 7
TABLE M A I L
DESCRIPTION OF ELEMENTS IF NOPTFI = 0
| ELEMENT | TYPE | NBER OF WORDS| S-D | TABLES | NBER OF NODES |
| 1 | 1 | 0 | 1 | 0 | 6 |
NODE NUMBERS : 152 176 154 163 164 153
NUMBER OF POINTS 3 : 1 2 3
| 2 | 1 | 0 | 1 | 0 | 6 |
NODE NUMBERS : 176 178 154 177 166 164
NUMBER OF POINTS 3 : 2 4 3
| 3 | 1 | 4 | 1 | 1 | 6 |
NODE NUMBERS : 154 178 158 166 167 157
NUMBER OF POINTS 3 : 3 4 5
REFERENCE (VERTICES) : 0 0 2
PRINT OUT OF D.S. COOR OF LEVEL 1
TITLE :
DATA STRUCTURE TYPE : COOR
TABLE C O O 2
TYPE OF THE TABLE COO4 (NTYT) : 2
NUMBER OF ITS INDEX (NINDI) : 2
MAX VALUE OF THE SECOND INDEX (M2) : 95
SEGMENTATION CODE (NCODS) : 1
NUMBER OF BLOCKS (NBLOC) : 1
TYPE OF THE COORDINATE AXIS (NTACOO) : 1
TABLE C O O 3
TABLE OF THE LAST COLUMN NUMBER OF EACH PAGE
PAGE 1 : 95 PAGE
TABLE C O O 4
PRINT OUT OF D.S. TAE OF LEVEL 1
TITLE :
DATA STRUCTURE TYPE : TAE
TABLE T A E 2
NUMBER OF ARRAYS CORRESPONDING TO EACH ELEMENT (NTACE) : 3
MAX NUMBER OF NODES PER ELEMENT (NNOMAX) : 6
CONSTANT NUMBER OF D.O.F. PER NODE ( 0 IF NOT ) (ND) : 2
MAXIMUM NUMBER OF D.O.F. PER NODE (NDLMAX) : 2
SUM OF THE NUMBER OF NODES OF THESE ELEMENT TYPES (LNOET) : 6
PROBLEM : 1 THERMAL, 2 ELASTIC, 3 OTHER (NPROV) : 2
REQUESTED OPTION (NOPTNT) : 111
NUMBER OF THE ASSOCIATED ARRAY CONTAINING :
THE MASS MATRIX : 0
THE STIFFNESS MATRIX : 1
THE FIRST LINEAR COMBINATION : 0
THE LAST ONE : 0
THE RIGHT HAND SIDE(S) : 2
THE STRESSES OR THE FLUX : 3
TABLE T A E 3
NUMBER OF NODES BY TYPE OF ELEMENT : 6
NUMBER OF D.O.F. AT EACH NODE : 2 2 2 2 2 2
TABLE T A E 4
ASSOCIATED ARRAY NUMBER ------------ : 1
MAX NUMBER OF WORDS NECESSARY FOR STORAGE (NMMAST) : 156
TYPE OF THE ARRAY (NTYTA) : 5
NUMBER OF INDICES (NINDI) : 1
STORAGE OPTION (NSTOC) : 1
TABLE T A E 4
ASSOCIATED ARRAY NUMBER ------------ : 2
MAX NUMBER OF WORDS NECESSARY FOR STORAGE (NMMAST) : 24
NUMBER OF INDICES (NINDI) : 2
STORAGE OPTION (NSTOC) : -1
TABLE T A E 4
ASSOCIATED ARRAY NUMBER ------------ : 3
MAX NUMBER OF WORDS NECESSARY FOR STORAGE (NMMAST) : 84
ELEMENT : 1 TYPE : 1 NUMBER OF NODES : 6
THEIR NUMBERS : 152 176 154 163 164 153
ELEMENT : 1 , ASSOCIATED ARRAY NUMBER : 1
1 0.381110E+05 2 0.200000E+05 3 0.423335E+05 4 0.899993E+04
7 0.333333E+04 8 0.299998E+04 9 0.000000E+00 10 0.899993E+04
13 0.000000E+00 14 -0.333333E+04 15 0.111112E+05 16 0.333333E+04
19 0.000000E+00 20 0.000000E+00 21 0.333336E+05 22 -0.359997E+05
25 -0.133333E+05 26 0.000000E+00 27 0.000000E+00 28 0.101629E+06
31 -0.133333E+05 32 -0.119999E+05 33 0.000000E+00 34 0.000000E+00
37 0.000000E+00 38 0.000000E+00 39 0.000000E+00 40 0.133333E+05
43 -0.296299E+05 44 -0.266667E+05 45 0.101629E+06 46 0.000000E+00
49 0.000000E+00 50 0.133333E+05 51 0.000000E+00 52 -0.266667E+05
55 0.112889E+06 56 -0.148149E+05 57 -0.133333E+05 58 0.000000E+00
61 -0.133333E+05 62 0.000000E+00 63 0.266667E+05 64 -0.719994E+05
67 -0.133333E+05 68 -0.444448E+05 69 0.000000E+00 70 0.000000E+00
73 0.266667E+05 74 0.000000E+00 75 -0.266667E+05 76 -0.239998E+05
ELEMENT : 1 , ASSOCIATED ARRAY NUMBER : 2
1 0.000000E+00 2 0.000000E+00 3 0.000000E+00 4 0.000000E+00
7 0.000000E+00 8 0.000000E+00 9 0.000000E+00 10 0.000000E+00
PRINT OUT OF D.S. BDCL OF LEVEL 1
TITLE :
DATA STRUCTURE TYPE : BDCL
TABLE B D C 2
TYPE OF CONSTRAINED VALUES (NTYB) : 5
NUMBER OF CARDS DESCRIBING CONSTRAINTS (NCART) : 18
NUMBER OF LINEAR RELATIONS BETWEEN CONSTRAINTS (NCLRL) : 0
STORAGE OPTION (NOPTFI) : 0
NUMBER OF WORDS OF TABLE BDC3 (NMMAT3) : 54
NUMBER OF WORDS OF TABLE BDC4 (NMMAT4) : 36
NUMBER OF WORDS OF TABLE BDC5 (NMMAT5) : 0
NUMBER OF WORDS OF TABLE BDC6 (NMMAT6) : 0
TABLE B D C 3 B D C 4
CLAMPING TYPE : 1 : NODE : 1 , D.O.F. : 1
AT VALUE : 0.00000000000000000E+00
CLAMPING TYPE : 1 : NODE : 1 , D.O.F. : 2
CLAMPING TYPE : 1 : NODE : 2 , D.O.F. : 1
CLAMPING TYPE : 1 : NODE : 2 , D.O.F. : 2
CLAMPING TYPE : 1 : NODE : 5 , D.O.F. : 1
CLAMPING TYPE : 1 : NODE : 5 , D.O.F. : 2
CLAMPING TYPE : 1 : NODE : 6 , D.O.F. : 1
CLAMPING TYPE : 1 : NODE : 6 , D.O.F. : 2
CLAMPING TYPE : 1 : NODE : 8 , D.O.F. : 1
CLAMPING TYPE : 1 : NODE : 8 , D.O.F. : 2
PRINT OUT OF D.S. B OF LEVEL 1
TITLE :
LEVEL AND STATE NUMBER : 1 2
TABLE B 2
TYPE OF THE TABLE (NTYT) : 5
NUMBER OF INDICES AND THEIR MAX VALUES (NIND..) : 2 1 666
OPTION (1: PAGES OF SAME SIZE , 0: IF NOT) (NCOD) : 1
NUMBER OF PAGES OF THE TABLE B4 (NBLOC) : 1
NUMBER OF TABLES B4 IN THIS D.S. (NBBLOC) : 1
CONSTANT NUMBER OF D.O.F. AT EACH NODE OR 0 (ND) : 2
NUMBER OF D.O.F. OR LENGHT OF A B4 PAGE (NTDL) : 666
STORAGE OPTION FOR B4 (NCODSB) : -1
TABLE B 3
POINTER ON THE LAST ROW OF EACH PAGE OF B4
1 0 2 666
TABLE B4(NDSM,NTDL) NUMBER : 1
TABLE B4(NDSM,NTDL) PAGINATED IN 1 OR MORE PAGES
PAGE 1
| NODE | DOF | GLOBAL DOF| LOAD CASE(S) |
| 1 | 1 | 1 | 0.000000
| 2 | 2 | 0.000000
| 2 | 1 | 3 | 0.000000
| 2 | 4 | 0.000000
| 3 | 1 | 5 | -0.161109E-18
| 2 | 6 | -0.347244E-05
| 4 | 1 | 7 | 0.649441E-05
| 2 | 8 | -0.399245E-05
| 5 | 1 | 9 | 0.000000
| 2 | 10 | 0.000000
PRINT OUT OF D.S. TAE OF LEVEL 2
TITLE :
LEVEL AND STATE NUMBER : 2 -1
TABLE T A E 2
NUMBER OF ARRAYS CORRESPONDING TO EACH ELEMENT (NTACE) : 1
REQUESTED OPTION (NOPTNT) : 0
THE MASS MATRIX : 0
THE STIFFNESS MATRIX : 0
THE LAST ONE : 0
THE RIGHT HAND SIDE(S) : 0
THE STRESSES OR THE FLUX : 1
TABLE T A E 3
TABLE T A E 4
ELEMENT : 1 NDSD : 1
-1 10 12 2 2 1 5 1 3 0
1 9.25925 2 0.333333
1 0.270955E+00 2 -0.689490E-03 3 -0.142846E+00
A plot of the deformation is generated by the preprocessor TRNOXX as follows:
| Call preprocessor: | TRNOXX |
| Specify input data structures: | T5NOPO |
| T5B |
Figure 3.6: The deformation ( TRNOXX)
The plots of the principal stresses, and stresses according to Tresca's criterion [MODULEF User Guide - 6], are generated by the preprocessor TRSTXX as follows:
| Call preprocessor: | TRSTXX |
| Specify input data structures: | T5MAIL |
| T5COOR | |
| T5TAES |
Figure 3.7: Principal stresses ( TRSTXX)
Figure 3.8: Stresses according to Tresca's criterion ( TRSTXX)
