Modulefpreviousupnextcontents[BIG][Normal][small]
Next: Part III: Installation Up: 3 Batch tests Prev: 3.2 Test 5: Elasticity Problem Contents
3.3 Test 6: Fluid Mechanics Problem
3.3.1 Description
Figure 3.9: Square cavity with free wall
The domain is a unit square with boundary conditions as follows: on the boundary
and on the remaining boundaries
We solve the Navier-Stokes problem with Stokes initialization using module NSQ2CA [59].
Aim and limitations of module NSQ2CA:
The mesh consists of 64 regular quadrangles (see figure 3.10).
Figure 3.10: Suggested mesh
3.3.2 The continuous problem
Let be a region in (N = 2 in this case) with boundary , then the flow of a viscous fluid in is governed by the Navier Stokes equations:
where
is the velocity vector ,
is the pressure,
is the velocity on the boundary,
is the kinematic viscosity of the fluid,
where
is the Reynold's number, and
are the characteristic velocity and length,
is the initial velocity.
Set Re = 100
3.3.3 Execution of the test
Step 1: Creation of Mesh
Execute program: D6NOXX
Modules used: APNOPO ... 2D mesh generator [MODULEF User Guide - 3]
QUACOO ... mesh using quadrangles
ADPNOP ... addition of nodes
GIBBS ... renumbering of nodes
Libraries used: NOP2, NOPO, UTSD, UTII
Input data file: D6NOPO.D
Output data structure: T6NOPO
Step 2: Solution of problem
Execute program: D6NSXX
Modules used: NSQ2CA ... solve Navier-Stokes equations
PRP1Q2 ... calculate the Q2 pressures
Libraries used: FLUI RESD, UTSD, UTII
Output data structures: T6VITE ... contains 3 arrays corresponding to the velocity at iterations 20, 40 and at the solution,
T6PRES ... contains the P1 discontinuous pressure at iterations 20, 40 and at the final iteration, and
T6PRQ2 ... contains the Q2 pressure (pressure values at the 9 nodes of the quadrangle).
The user functions FX and FY represents the velocity as a function of x and y and of the reference numbers on the boundary of the domain. These functions are found at the end of program D6NSXX stored in file D6NSXX.F.
3.3.4 Convergence
The solution obtained at iterations 20, 40, and finally at 7.05 seconds, are:
Relative Iteration N 20 Iteration N 40 Iteration N 47
Error Time = 3 sec Time = 6 sec Time = 7.05 sec
L
L
L
The profile matrix occupies 933 words .
3.3.5 Results
The output of the 3 D.S. B, at iteration 47 is stored in library TESD under the following names:
S6VITE.D
output of the velocity
S6PRES.D
output of the P1 pressure
S6PRQ2.D
output of the Q2 pressure
The remainder of this section contains the partial or total printout of the various D.S. created in the different steps. These data structures can be viewed by calling preprocessor IMAGXX and specifying the names of the files containing the desired data structures.
     PRINT OUT OF D.S. NOPO OF LEVEL  1
 TITLE                           : BENCHMARK MODULEF NUMBER 6 :NAVIER STOKES
 DATE AND USER'S NAME            : 14/09/90  dutoit
 DATA STRUCTURE TYPE             : NOPO
 LEVEL AND STATE NUMBER          :      1     0
 NUMBER OF ASSOCIATED TABLES     :      0
 TABLE  N O P 2
 CHARACTERISTICS OF THE MESH :
 SPACE DIMENSION                        (NDIM ) :      2
 MAXIMUM NUMBER OF REFERENCES           (NDSR ) :      2
 MAXIMUM NUMBER OF SUB-DOMAINS          (NDSD ) :      1
 NODES AND POINTS DO NOT COINCIDE      (NCOPNP) :      0
 NUMBER OF ELEMENTS                     (NE   ) :     64
 NUMBER OF QUADRANGLES                  (NQUA ) :     64
 NUMBER OF BOUNDARY ELEMENTS            (NEF  ) :     28
 NUMBER OF NODES                        (NOE  ) :    289
 NUMBER OF NODES BY SEGMENT (NO EXTREMITIES)    :      1
 NUMBER OF INTERNAL NODES     :
 AT EACH QUADRANGLE                     (ISEQ ) :      1
 NUMBER OF POINTS                        (NP  ) :     81
 TYPE OF COORDINATE VALUES             (NTYCOO) : REEL1MOT
 MAX DIFFERENCE +1 BETWEEN 2 NODES OF AN ELEMENT :    55
 NUMBER OF COARSE ELEMENTS             (NBEGM ) :      0
 NUMBER OF WORDS FOR TABLE NOP5        (LNOP5 ) :   1404
 REFERENCE AXIS    X,Y,Z               (NTACOO) :      1
  TABLE  N O P 4
  COORDINATES OF POINTS
 | POINT |     X        |     Y       |   | POINT |     X        |     Y       |
 |     1 |  0.000000    | 0.000000    |   |     2 |  0.000000    | 0.250000    |
 |     3 |  0.000000    | 0.500000    |   |     4 |  0.000000    | 0.750000    |
 |     5 |  0.000000    |  1.00000    |   |     6 |  0.250000    | 0.000000    |
 |     7 |  0.250000    | 0.250000    |   |     8 |  0.250000    | 0.500000    |
 |     9 |  0.250000    | 0.750000    |   |    10 |  0.250000    |  1.00000    |
  TABLE  N O P 5
  DESCRIPTION OF ELEMENTS
 | ELEMENT :      1 | QUADRANGLE   | S-D :   1 | NUMBER OF STORED WORDS  :  9
 NUMBER OF  NODES  :  9 :        1       35       37        5        2       36
                                 6        3        4
 NUMBER OF  POINTS :  4 :        1       26       66       29
  EDGE REFERENCE        :        1        0        0        1
  VERTEX REFERENCE      :        1        1        0        1
     PRINT OUT OF D.S. B    OF LEVEL  1    (T6VITE)
 TITLE                           :
 DATA STRUCTURE TYPE             : B
 TABLE  B 2
 TYPE OF THE TABLE                           (NTYT) :      2
 NUMBER OF INDICES AND THEIR MAX VALUES    (NIND..) :      2     1   578
 OPTION (1: PAGES OF SAME SIZE , 0: IF NOT)  (NCOD) :      1
 NUMBER OF PAGES OF THE TABLE B4            (NBLOC) :      1
 NUMBER OF NODES                              (NOE) :    289
 NUMBER OF TABLES B4 IN THIS D.S.          (NBBLOC) :      3
 CONSTANT NUMBER OF D.O.F. AT EACH NODE OR 0   (ND) :      2
 NUMBER OF D.O.F. OR LENGHT OF A B4 PAGE     (NTDL) :    578
 STORAGE OPTION FOR B4                     (NCODSB) :     -1
 TABLE  B 3
  POINTER ON THE LAST ROW OF EACH PAGE OF B4
     1           0     2         578
 TABLE B4(NDSM,NTDL) NUMBER :      1
  TABLE B4(NDSM,NTDL) PAGINATED IN 1 OR MORE PAGES
  PAGE     1
 | NODE   | DOF | GLOBAL DOF|  LOAD CASE(S)           |
 |      1 |   1 |        1  |    0.000000
          |   2 |        2  |    0.000000
 |      2 |   1 |        3  |    0.000000
          |   2 |        4  |    0.000000
 |      3 |   1 |        5  |    0.000000
          |   2 |        6  |    0.000000
 |      4 |   1 |        7  |   -0.873772E-03
          |   2 |        8  |    0.842329E-03
 |      5 |   1 |        9  |    0.000000
          |   2 |       10  |    0.000000
 TABLE B4(NDSM,NTDL) NUMBER :      2
  PAGE     1
          |   2 |        2  |    0.000000
          |   2 |        4  |    0.000000
          |   2 |        6  |    0.000000
 |      4 |   1 |        7  |   -0.888998E-03
          |   2 |        8  |    0.832968E-03
          |   2 |       10  |    0.000000
 TABLE B4(NDSM,NTDL) NUMBER :      3
  PAGE     1
          |   2 |        2  |    0.000000
          |   2 |        4  |    0.000000
          |   2 |        6  |    0.000000
 |      4 |   1 |        7  |   -0.983558E-03
          |   2 |        8  |    0.929105E-03
          |   2 |       10  |    0.000000
     PRINT OUT OF D.S. B    OF LEVEL  2        (T6PRES)
 TITLE                           :
 LEVEL AND STATE NUMBER          :      2     0
 TABLE  B 2
 NUMBER OF INDICES AND THEIR MAX VALUES    (NIND..) :      2     1   192
 NUMBER OF NODES                              (NOE) :     64
 CONSTANT NUMBER OF D.O.F. AT EACH NODE OR 0   (ND) :      3
 NUMBER OF D.O.F. OR LENGHT OF A B4 PAGE     (NTDL) :    192
 TABLE  B 3
     1           0     2         192
  PAGE     1
 |      1 |   1 |        1  |   -0.830884E-02
          |   2 |        2  |    0.843354E-02
          |   3 |        3  |    0.000000
 |      2 |   1 |        4  |   -0.364164E-02
          |   2 |        5  |    0.131478E-01
          |   3 |        6  |   -0.115603E-02
 |      3 |   1 |        7  |   -0.170311E-01
          |   2 |        8  |    0.475959E-02
          |   3 |        9  |    0.124966E-02
 |      4 |   1 |       10  |   -0.344920E-02
  PAGE     1
 |      1 |   1 |        1  |   -0.781133E-02
          |   2 |        2  |    0.778977E-02
          |   3 |        3  |    0.000000
 |      2 |   1 |        4  |   -0.406640E-02
          |   2 |        5  |    0.120007E-01
          |   3 |        6  |   -0.961857E-03
 |      3 |   1 |        7  |   -0.160561E-01
          |   2 |        8  |    0.915468E-03
          |   3 |        9  |    0.164742E-02
 |      4 |   1 |       10  |   -0.450665E-02
  PAGE     1
 |      1 |   1 |        1  |   -0.801085E-02
          |   2 |        2  |    0.795096E-02
          |   3 |        3  |    0.000000
 |      2 |   1 |        4  |   -0.321434E-02
          |   2 |        5  |    0.123081E-01
          |   3 |        6  |   -0.109873E-02
 |      3 |   1 |        7  |   -0.161097E-01
          |   2 |        8  |   -0.420842E-03
          |   3 |        9  |    0.183181E-02
 |      4 |   1 |       10  |   -0.344618E-02
     PRINT OUT OF D.S. B    OF LEVEL  3       (T6PRQ2)
 TITLE                           :
 LEVEL AND STATE NUMBER          :      3     0
 TABLE  B 2
 NUMBER OF INDICES AND THEIR MAX VALUES    (NIND..) :      2     1   289
 NUMBER OF TABLES B4 IN THIS D.S.          (NBBLOC) :      4
 CONSTANT NUMBER OF D.O.F. AT EACH NODE OR 0   (ND) :      1
 NUMBER OF D.O.F. OR LENGHT OF A B4 PAGE     (NTDL) :    289
 TABLE  B 3
     1           0     2         289
  PAGE     1
 |      2 |   1 |        2  |   -0.519302E-03
 |      3 |   1 |        3  |    0.527096E-03
 |      4 |   1 |        4  |    0.779354E-05
 |      5 |   1 |        5  |    0.144940E-02
 |      6 |   1 |        6  |    0.657526E-03
 |      7 |   1 |        7  |    0.214208E-02
 |      8 |   1 |        8  |    0.107764E-02
 |      9 |   1 |        9  |    0.288912E-02
 |     10 |   1 |       10  |    0.145768E-02
  PAGE     1
 |      2 |   1 |        2  |   -0.488208E-03
 |      3 |   1 |        3  |    0.486861E-03
 |      4 |   1 |        4  |   -0.134727E-05
 |      5 |   1 |        5  |    0.136779E-02
 |      6 |   1 |        6  |    0.621930E-03
 |      7 |   1 |        7  |    0.181907E-02
 |      8 |   1 |        8  |    0.815563E-03
 |      9 |   1 |        9  |    0.225265E-02
 |     10 |   1 |       10  |    0.954031E-03
  PAGE     1
 |      2 |   1 |        2  |   -0.500678E-03
 |      3 |   1 |        3  |    0.496935E-03
 |      4 |   1 |        4  |   -0.374275E-05
 |      5 |   1 |        5  |    0.138654E-02
 |      6 |   1 |        6  |    0.632771E-03
 |      7 |   1 |        7  |    0.175291E-02
 |      8 |   1 |        8  |    0.746048E-03
 |      9 |   1 |        9  |    0.206836E-02
 |     10 |   1 |       10  |    0.794842E-03
 TABLE B4(NDSM,NTDL) NUMBER :      4
  PAGE     1
 |      2 |   1 |        2  |   -0.506843E-03
 |      3 |   1 |        3  |    0.502850E-03
 |      4 |   1 |        4  |   -0.399328E-05
 |      5 |   1 |        5  |    0.140208E-02
 |      6 |   1 |        6  |    0.640137E-03
 |      7 |   1 |        7  |    0.177119E-02
 |      8 |   1 |        8  |    0.754146E-03
 |      9 |   1 |        9  |    0.208460E-02
 |     10 |   1 |       10  |    0.801812E-03
3.3.6 Post-processing
The procedures for plotting the velocities, isobars, and streamlines, are described below:
  1. Plot of the velocities
    The Q2 velocity values are stored in file T6VITE. The plot of the velocity distribution is generated by the preprocessor TRMCXX [MODULEF User Guide - 6] (see figure 3.11). Before execution of TRMCXX it is necessary to create the data structures MAIL and COOR corresponding to the NOPO data structure for the Q2 mesh.
    Step 1:
    Call preprocessor: COMAXX
    Specify input data file: D6COMA.D ... in library TESD
    Output data structures: T6MAIL
    T6COOR
    Step 2:
    Call preprocessor: TRMCXX
    Specify input data structures: T6MAIL
    T6COOR
    T6VITE
    Figure 3.11: Velocity distribution ( TRMCXX)
  2. Plot of the isobars
    The values of the Q2 pressure are stored in file T6PRQ2. A plot of the isobars is generated by preprocessor TRMCXX [MODULEF User Guide - 6] (see figure 3.12). As before, data structures MAIL and COOR are necessary as input in preprocessor TRMCXX.
    T6COOR
    T6PRQ2
    Figure 3.12: Isobars ( TRMCXX)
  3. Plot of the streamlines
    The streamlines are calculated using the velocity values by solving the following system:
    where
    is the streamline function,
    is the velocity, and
    is the tangent.
    Remark: For the case where on a section of the boundary, we may impose that on and the preceding Neumann condition on the remainder of the boundary.
    A better conditioned system is obtained admitting one unique solution. The system is solved by the same preprocessors as was used in the solution of the thermal problem with a QUAD 2Q2D element:
    Step 1: Interpolation [13]
    Element type: QUAD 2Q2D
    T6COOR
    Step 2: Description of data [14]
    Call preprocessor: FOMIXX
    Specify input data file: D6FOMI.D ... in library TESD
    Output data structures: T6FORC
    T6MILI
    Step 3: Calculation of the element arrays [14]
    Execute program: D6CAXX ... in library TEST
    T6COOR
    T6MILI
    T6FORC
    T6VITE
    Output data structure: T6TAE
    Step 4: Description of boundary conditions [18]
    Call preprocessor: COBDXX
    Specify input data file: D6BDCL.D ... in library TESD
    Output data structure: T6BDCL
    Step 5: Solution [MODULEF User Guide - 5]
    Call preprocessor: CHOLXX
    Specify input data file: D6B.D ... in library TESD
    A plot of the streamlines is generated by preprocessor TRMCXX as follows:
    T6COOR
    T6B
Figure 3.13: Streamlines
