Next: 2.3 Organization of the MODULEF library
Up: 2 Installation procedure: UNIX
Prev: 2.1 The installation procedure:
Contents
You are not obliged to restart the entire execution of
the Makefile, but only need to restart a Makefile target
( make target name), for example after an interruption.
To do this, you need to place yourself in directory $MR/Install$MM.
The targets which can be executed are the following:
- librairies
- : compile the source libraries;
- executables
- : create the executable programs again;
- POBA POBV
- : create the direct access files poba.direct or pobn.direct;
- TEST
- : create the executable programs corresponding to the test programs;
- clean
- : delete all the Makefile files contained in the source libraries;
- cleantrad
- : delete all the files generated during the
execution of the target traduction: delete all files with the
suffixes .original et .ftn ;
- veryclean
- : execute the targets clean and
cleantrad, delete the directory containing all the binary files ( $MR/$MM);
- gestion
- : create two files, used by the management commands (see chapter 5);
- traduction
- : translate the MODULEF source into English or
French). This target must be executed before
compiling (target librairies). The translation is only performed if variable
LANGUAGE is not empty.
The print formats are translate
- in English if LANGUAGE=GB
- in French if LANGUAGE=F
During the translation, only the Fortran files with a translated
version different from the initial version are updated, the initial
version is saved in files with suffix .original.
- traduction_origine
- : the Modulef libraries are put in the
state they were before the execution of the traduction target;
- graphique
- : create, according your graphic peripheral
choice, subroutines perfgn and itrctg, compile them and
verify if the corresponding archives are up to date.
An archive library, a MODULEF main program, the translation of a library can also be generated in the same manner, by initiating the commands:
- make name of the source library, for example: make nopo
- make PP_ name of the main program, for example: make PP_thelxx
- make trad_ name of the library :
translate the library in the language defined by the variable
LANGUAGE for example: make trad_emc2
- make trad_o_ name of the library : puts in
its initial state the library, for example:
make trad_o_emc2
This utilization of the Makefile is particularly interesting when we notice that, after
having launched the Makefile, certain compilations were not performed correctly,
or if we forgot to create certain executables.
After the MODULEF installation, you need to
- adapt the management commands at you site
- and, to ensure successful execution of the programs, initialize variables
MR, MM and MV in your environment,
You may now execute the test contained in libraries test and tesd
(see Part ii in this user guide). If you wish to produce hard-copies or
postscript graphics, it is necessary to adapt command prf_f3d contained in directory
$MR/ascii/com.util at your site (see section 4.3.3).
Contents
