Next: 4.7 Tests and normal utilization
Up: 4 Generalities
Prev: 4.5 Creation of the procedure data
Contents
Some MODULEF subroutines (computation of element arrays: mass or stiffness matrix, RHS vector, etc.) may read numerical values from a particular file, called POBA, which must be generated once only at the time of installation. This file is generated by running the main program, POBAXX in library PPAL. The list of subroutines required for this operation is obtained by interrogating the procedure base with PROIMP (see section 4.5).
Furthermore, program POBAXX:
The following listing is obtained on UNIX:
$ head -3 poba.d $ HEXAEDRE Q2 $ $ IP LA PERMUTATION DE COMPOSANTE PAR COMPOSANTE A NOEUD PAR NOEUD 1 4 7 10 13 16 19 22 25 28 31 34 37 40 43 46 49 52 $ tail -3 poba.d $OA P 18 $ +00.0 +00.0 +00.0 +00.0 +16.0 +00.0 +00.0 +00.0 +00.0 $ P 18 $ +00.0 +00.0 +00.0 +00.0 -16.0 +00.0 +00.0 +00.0 +00.0 $ $ pobaxx NAME OF DATA FILE ? poba.d NAME OF FILE POBA ? poba.direct TABLE 3Q2I WITH ADDRESS 11 HAS 134 WORDS ITS FIRST PAGE IS 2 1 4 7 10 13 16 19 22 25 28 31 34 37 40 43 46 49 52 55 58 2 5 8 11 14 17 20 23 26 29 32 35 38 41 44 47 ... END NORMAL ( POBA ) : NUMBER OF TABLES (NBTAST) : 49 NUMBER OF PAGES (NODEPA) : 209 DESCRIPTION OF THE TABLES : ------------------------- 3Q2I 0 134 2 3Q2P 0 1080 3 3Q1P 0 128 8 3Q2Q 0 3240 9 3Q2V 0 1080 22 3Q1V 0 432 27 .... EMPTY 0 0 0 EMPTY 0 0 0 EMPTY 0 0 0 EMPTY 0 FORTRAN STOP
