Modulefpreviousupnextcontentsindex[BIG][Normal][small]
Next: 5.3 A three-dimensional example Up: 5.2 A two-dimensional example Prev: 5.2.1 Top-down analysis Index Contents
5.2.2 Bottom-up construction
Starting from the "highest" notion, the domain, we distinguished the different useful notions in the preceding section: mesh generators, contours, lines, points. The actual creation of the mesh is performed in the inverse direction, i.e., by starting from the "lowest" notion, the point, in order to define the domain step by step.
Figure 5.2: The characteristic items
Figure 5.2 indicates the 13 points necessary to define the geometry. The 16 lines used for the construction are also shown. Next, the contours are formed:
i
for the shield: lines l1, l7, l5, l6, in this order. The number of points on lines l1 and l5, on the one hand, and those on l7 and l6 on the other hand, are equal.
ii
for the air zone: lines l2, l3, l4, l7, l8, l16, l13, l12, in this order. As l2 is defined from point P2 to point P3, the direction of l2 is positive when traversing the contour. Note that the 4 last lines are input in the negative direction (to indicate the presence of a hole), consequently l8 will be traversed in reverse (in relation to its definition).
iii
for the circle: the set of lines l10, l11, are defined via a function parser. Consequently, these 2 lines will have a geometric description number assigned to indicate this option and, as reference number, have the number given to this curve. Furthermore, it is necessary to ensure that these lines are defined in the positive direction (by the choice of their 2 end-points).
iv
for the semiconductor: lines l8, l9, l10, l11, l14, l16; the first line (l8) of this contour is seen in the positive direction.
v
for the half-cooling circuit: lines l15, l11, l10; by choosing l15 as the first line it means that it is seen in its defined direction.
Figure 5.3: The meshed domain
The data file is given below:
'PART_OVEN                                                           '
 COURBES
     1                                 $ IMPRE
 COURBE01(X,Y)=
       X*X+Y*Y-4.;
FIN
'POINTS                                                              '
     1    13                            $ IMPRE NPOINT  $
$   NOP   NOREF(NOP)     X(NOP).            Y(NOP).  $
     1       0         -.525000E+01     -.300000E+01
     2       0         -.300000E+01     -.300000E+01
     3       0         0.500000E+01     -.300000E+01
     4       0         -.212132E+01     -.212132E+01
     5       0         0.212132E+01     -.212132E+01
     6       1         -.141421E+01     -.141421E+01
     7       1         0.141421E+01     -.141421E+01
     8       1         -.141421E+01     0.141421E+01
     9       0         -.212132E+01     0.212132E+01
    10       0         0.212132E+01     0.212132E+01
    11       0         -.525000E+01     0.300000E+01
    12       0         -.300000E+01     0.300000E+01
    13       0         0.500000E+01     0.300000E+01
'LIGNES                                                              '
     1    16                            $ IMPRE  NDLM   $
$   NOLIG NOELIG NEXTR1 NEXTR2 NOREFL NFFRON       RAISON $
       1      5      1      2      0      0     0.100000E+01
       2     10      2      3      0      0     0.100000E+01
       3      8      3     13      0      0     0.100000E+01
       4     10     13     12      0      0     0.100000E+01
       5      5     12     11      0      0     0.100000E+01
       6      8     11      1      0      0     0.100000E+01
       7      8      2     12      0      0     0.100000E+01
       8      7      4      5      0      0     0.100000E+01
       9      2      5      7      0      0     0.100000E+01
      10      6      6      7      1     10     0.100000E+01
      11      6      8      6      1     10     0.100000E+01
      12      7      5     10      0      0     0.100000E+01
      13      7     10      9      0      0     0.100000E+01
      14      2      8      9      0      0     0.100000E+01
      15      8      7      8      0      0     0.100000E+01
      16      7      9      4      0      0     0.100000E+01
'QUAC        '
     1     0     4     4     1          $ IMPRE NIVEAU NUDSD NBRELI NS1L
 $ LIST OF CONTOUR LINES :
     1     7     5     6
     5     1                            $ IMAX NQUAD
'TRIH        '
     1     1     3     8     1          $ IMPRE NIVEAU NUDSD NBRELI NS1L
     2     3     4     7     8    16    13    12
     2     0     1                      $ NCOMP NBRINT IOPT $
     4                                  $ COMPONENT $
     -4                                 $ COMPONENT $
'TRIH        '
     1     2     2     6     1          $ IMPRE NIVEAU NUDSD NBRELI NS1L
     8     9    10    11    14    16
     1     0     1                      $ NCOMP NBRINT IOPT $
     6                                  $ COMPONENT $
'TRIH        '
     1     3     1     3     1          $ IMPRE NIVEAU NUDSD NBRELI NS1L
    15    11    10
     3                                  $ COMPONENT $
'RECO        '
    1    2    3    4  0.10000E-02    1  $ IMP NIV1 NIV2 NIV3 EPS IOPT
     0     0                            $ NBNNF NBNNSD
'SYMD        '
     1     4     2                      $ IMPRE NIVEA1 NIVEA2
     0     0                            $ NBNNF NBNNSD
  0.10000E+01  0.10000E+01  0.00000E+00 $ A. B. C.
'RECO        '
    1    4    2    3  0.10000E-02    1  $ IMP NIV1 NIV2 NIV3 EPS IOPT
     0     0                            $ NBNNF NBNNSD
'RECO        '
    1    3    1    2  0.10000E-02    1  $ IMP NIV1 NIV2 NIV3 EPS IOPT
     0     0                            $ NBNNF NBNNSD
'RECO        '
    1    2    0    1  0.10000E-02    1  $ IMP NIV1 NIV2 NIV3 EPS IOPT
     0     0                            $ NBNNF NBNNSD
'RENC        '
     1     1     0                      $ IMPRE NIVEA1 NIVEA2
'SAUV        '
     1     0     0                      $ IMPRE NINOPO NTNOPO
 OVEN.NOPO
 $ FILE NAME
'F        '
The following listing is obtained during execution of APNOXX:
 EXECUTING APNOPO : ( 2D MESH )
 -- CREATE THE DATA  =-=  EXECUTE MODULE (DATA EXISTING)  =-=  END  =-=  ?
E
 -- NAME OF THE DATA FILE ?
oven.data
 COURBES
 ** PROCESSING OF KEYWORD COUR
 ++ OPEN(11,FILE='',SPEC='SCRATCH,UNFORMATTED',RECL=0)
 POINTS
 ** PROCESSING OF KEYWORD POIN
 LIGNES
 ** PROCESSING OF KEYWORD LIGN
 QUAC
 ** PROCESSING OF KEYWORD QUAC
 MODULE QUACOO : PART_OVEN
 END OF MODULE QUACOO
 TRIH
 ** PROCESSING OF KEYWORD TRIH
 MODULE TRIHER :
 END OF MODULE TRIHER
 TRIH
 MODULE TRIHER :
 TRIH
 MODULE TRIHER :
 RECO
 ** PROCESSING OF KEYWORD RECO
 MODULE RECOLC : PART_OVEN
 FIN DU MODULE RECOLC
 SYMD
 ** PROCESSING OF KEYWORD SYMD
 MODULE MODNOP : PART_OVEN
 END OF MODULE MODNOP
 RECO
 RECO
 RECO
 RENC
 ** PROCESSING OF KEYWORD RENC
 MODULE GIBBS : PART_OVEN
 MODULE RENUM1 : PART_OVEN
 PERMUTATION OF COORDINATES
 RENUMBERING OF NODES
 NUMBER OF NODES :       152
 I CHARACTERISTICS    I BEFORE RENUMBERING  I AFTER RENUMBERING   I
 I BAND WIDTH         I             114     I              15     I
 I TOTAL PROFILE      I            3524     I            1706     I
 I MEAN PROFILE       I              23.184 I              11.224 I
 END OF MODULE RENUM1
 END OF MODULE GIBBS
 SAUV
 ** PROCESSING OF KEYWORD SAUV
 ++ OPEN(12,FILE='oven.nopo',SPEC='UNFORMATTED',RECL=0)
 F
 ** PROCESSING OF KEYWORD F
 END OF MODULE APNOPO
END
Some remarks
