Next: 3.3.3 Data definition
Up: 3.3 Extrusion method (cylindrical topology)
Prev: 3.3.1 Quick description of the method
Index
Contents
Warning: This version is no longer maintained or documented (as from the 1991 version of the code). One can nevertheless use it (for some time) via preprocessor MA2DXX which accepts the data files created formerly.
Recall that this former version only permitted construction by translation of 2D meshes and offered less suppleness for the definition of the physical attributes. We should also add that the current module, besides possessing numerous other possibilities, is distinctly faster than the former version.
