Modulefpreviousupnextcontentsindex[BIG][Normal][small]
Next: 3.4.3 Calling of module GEL3D1 Up: 3.4 Method for a hexahedral topology Prev: 3.4.1 Quick description of the method Index Contents
3.4.2 Description of the input data
This mesh generator requires all the information defining the 3 point distributions as input data.
The efficiency of the method results from the numerous possibilities offered to define the vertex coordinates. A vertex being known via its three indices i, j, k, it suffices to input the following data, in accordance to the case under consideration (see lower down):
The face, edge and point references of the mesh created are defined from their position (indices i, j, k), in the same way as the sub-domain numbers of the elements created (see further down).
