![[BIG]](../icons/zoom18.gif)
![[Normal]](../icons/zoom14.gif)
![[small]](../icons/zoom10.gif)
Next: 2 Iterative methods
Up: 1 Direct methods
Prev: 1.2 The modules
Contents
It could be interesting to use the algorithms directly, in particular to write an efficient
non-linear procedure. Two programs correspond to each module:
one in single precision (library RESR) and one in
double precision (library RESD).
In principle, the names of the two programs differ only in the last letter:
R in single precision, D in double.
- Matrix assembly
- ASDIAD vectorial assembly of a diagonal matrix in double precision,
- ASNSYD vectorial assembly of a non-symmetric matrix in double precision,
- ASSYMD vectorial assembly of a symmetric matrix in double precision,
- ASDIAR vectorial assembly of a diagonal matrix in single precision,
- ASNSYR vectorial assembly of a non-symmetric matrix in single precision,
- ASSYMR vectorial assembly of a symmetric matrix in single precision.
- Assembly of the right-hand-side
- ASSBPD assembly of the RHS in double precision (structure B in secondary memory),
- ASSMBD vectorial assembly of the RHS in double precision,
- ASSBPR assembly of the RHS in single precision (structure B in secondary memory),
- ASSMBR vectorial assembly of the RHS in single precision.
- Impose the boundary conditions
- CLBD1D boundary conditions of type
= V in double precision,
- CLBRLD boundary conditions i.t.o. linear relation in double precision,
- CLBD1R boundary conditions of type
= V in single precision,
- CLBRLR boundary conditions i.t.o. linear relation in single precision.
- Solution by direct method
- Factorization
- CHMC1D Cholesky factorization in main memory and in double precision,
- CRMC1D Crout factorization in main memory and in double precision,
- CRMC3D Gauss factorization in main memory and in double precision,
- CHMC1R Cholesky factorization in main memory and in single precision,
- CRMC1R Crout factorization in main memory and in single precision,
- CRMC3R Gauss factorization in main memory and in single precision.
- Solution by forward-and-backward substitution
- DRCH1D Cholesky forward-and-backward substitution in main memory and in double precision,
- DRCR1D Crout forward-and-backward substitution in main memory and in double precision,
- DRCR3D Gauss forward-and-backward substitution in main memory and in double precision,
- DRCH1R Cholesky forward-and-backward substitution in main memory and in single precision,
- DRCR1R Crout forward-and-backward substitution in main memory and in single precision,
- DRCR3R Gauss forward-and-backward substitution in main memory and in single precision.
Contents
