Modulefpreviousupnextcontents[BIG][Normal][small]
Next: 2 Iterative methods Up: 1 Direct methods Prev: 1.2 The modules Contents
1.3 The algorithms
It could be interesting to use the algorithms directly, in particular to write an efficient non-linear procedure. Two programs correspond to each module: one in single precision (library RESR) and one in double precision (library RESD). In principle, the names of the two programs differ only in the last letter: R in single precision, D in double.
1.3.1 List of programs
