- dimension array M (in the blank common),
- call INITI,
- create the input data structures MUA1 and MUA2.
Call the module:
CALL MUA2PC(M,ALPHA1,NFMUA1,NIMUA1,
+ ALPHA2,NFMUA2,NIMUA2,
+ NFMUAS,NIMUAS)
where:
- M: the super array,
- ALPHA1 (double precision): the multiplication coefficient of matrix A1,
- NFMUA1: the number of the support file of I.D.S. MUA: MUA1 (NFMUA1
- NIMUA1: its level number,
- ALPHA2 (double precision): the multiplication coefficient of matrix A2,
- NFMUA2: the number of the support file of I.D.S. AMUA: MUA2 (NFMUA2
- NIMUA2: its level number,
- NFMUAS: the number of the support file of O.D.S. MUA: MUAS (NFMUAS
- NIMUAS: its level number.
- Note:
- if NIMUA1=NIMUAS (resp. if NIMUA2=NIMUAS) the skyline
of A2 must be contained inside the skyline of A1 (resp. the skyline of A1 must be
contained inside that of A2).
In addition, if NIMUA1=NIMUA2, then NFMUA1 and NFMUA2 must be equal.
