- dimension array M (in the blank common),
- call INITI,
- create the input data structures B1 and B2.
Call the module:
CALL SDB2MC(M,ALPHA1,NDSM1,NFB1,NIB1,
+ ALPHA2,NDSM2,NFB2,NIB2,
+ NDSMS,NFBS,NIBS)
where:
- M: the super array,
- ALPHA1: double precision array, the multiplication coefficient of vector B1,
- NDSM1: maximum value of the first index of array B4 of structure B1,
- NFB1: the number of the support file of I.D.S. B: B1,
- NIB1: its level number,
- ALPHA2: the multiplication coefficient of vector B2,
- NDSM2: maximum value of the first index of array B4 of structure B2,
- NFB2: the number of the support file of I.D.S. B: B2,
- NIB2: its level number,
- NDSMS: maximum value of the first index of array B4 of structure BS,
- NFBS: the number of the support file of O.D.S. B: BS,
- NIBS: its level number,
- Note:
- if NIB1=NIBS (resp. if NIB2=NIBS)
then NDSM1 must be equal to NDSMS (resp. NDSM2=NDSMS).
