Modulefpreviousupnextcontents[BIG][Normal][small]
Next: 1.3 The non-symmetric model problem Up: 1 Examples Prev: 1.1 Introduction Contents
1.2 The symmetric model problem
The example chosen is the solution of a realistic linear elasticity problem by the finite element method: a hook, greased on part of its boundary, is submitted to a vertical traction force on the utility part. Given the envisaged boundary conditions, and the material assumed homogeneous isotropic, the problem exhibits a symmetry plane, so that the domain is reduced to a half-hook (see Figure 1).
For more details about the variational formulation of this problem, as well as its finite element approximation and the different aspects of the computer implementation, consult also [1]. Other numerical experiences concerning the solution of this problem are also found in this reference.
During numerical implementation, several distinctive steps appear before the actual solution:
Consult the corresponding guides for the utilization of these modules.
Figure 1.1: Mesh of the domain
The geometry of the model problem is described by a NOPO data structure, and a view of the object is presented in Figure 1.1. The mesh contains 1006 elements and 937 nodes, the finite elements used being of degree 1.
At each of the nodes, we need to compute the three displacement components, so that the resulting linear system has 2811 unknowns. The structure of the matrix of the linear system is represented in figure 1.2.
Figure 1.2: Matrix structure
To solve the linear system corresponding to the model problem, we need to:
We have already mentioned that each of these steps are performed by a distinct module; to simplify the utilization of the MODULEF code, sequences of these modules are programmed for each option available (the preprocessors of library PPAL). The user can also create his/her own sequences from the MODULEF programs.
We will now look at the different possibilities:
1.2.1 Solution by Cholesky in main memory
Main program CHOLXX successively calls modules PREPAC, ASSMUA, ASEMBV, CHOLPC and, lastly, DRCHPC. The listing of the data of CHOLXX is shown below:
 mail                                  $ FILE NAME
     1                                 $     AND LEVEL OF THE D.S. MAIL
     1     5     3                     $ NDSM  NTYP  ND
 tae                                   $ FILE NAME
     1                                 $     AND LEVEL OF THE D.S. TAE
     1                                 $ 1 IF BDCL IS USED , 0 IF NOT
 bdcl                                  $ FILE NAME
     1                                 $     AND LEVEL OF THE D.S. BDCL
     0                                 $ 1 IF BOUNDARY CONDITIONS I.T.O.
                                       $     LINEAR RELATIONS EXIST
 B                                     $ FILE NAME
     3                                 $ IMPREB
The results corresponding to an execution on a Hewlett-Packard Apollo series 400 workstation is given below:
 M   M    OOO    DDDD    U   U   L       EEEEE   FFFFF
 MM MM   O   O   D   D   U   U   L       E       F
 M M M   O   O   D   D   U   U   L       EEEE    FFFF
 M   M   O   O   D   D   U   U   L       E       F
 M   M    OOO    DDDD     UUU    LLLLL   EEEEE   F    VERSION 93
 DATE   : 14/06/93
 AUTEUR : dutoit
 EXECUTING THE CHOLESKY SOLUTION METHOD
 -- CREATE THE DATA  =-=  EXECUTE MODULE (DATA EXISTING)  =-=  END  =-=  ?
E
 -- NAME OF DATA FILE ?
dchol.data_gb
 -- PRINT PARAMETER FOR THE EXECUTION ?
3
 ++ OPEN(11,FILE='mail',SPEC='OLD,UNFORMATTED',RECL=0)
 ++ OPEN(12,FILE='tae',SPEC='OLD,UNFORMATTED',RECL=0)
 ++ OPEN(13,FILE='bdcl',SPEC='OLD,UNFORMATTED',RECL=0)
 ++ OPEN(14,FILE='crochet.bchol',SPEC='UNFORMATTED',RECL=0)
 MODULE PREPAC :
 NUMBER OF D.O.F. PER NODE          (ND) :      3
 NUMBER OF LOAD CASES             (NDSM) :      1
 PRESENCE OF LINEAR RELATIONS    (NCLRL) :      0
 MATRIX STORAGE CODE            (NCODSA) :      1
 TYPE OF TABLES                    (NTY) :      5
 INPUT D.S. MAIL      (NFMAIL ET NIMAIL) :     11     1
 INPUT D.S. NDL1      (NFNDL1 ET NINDL1) :      0     0
 INPUT D.S. BDCL      (NFBDCL ET NIBDCL) :     13     1
 OUTPUT D.S. MUA      (NFMUA  ET NIMUA ) :      0     0
 NUMBER OF ASSOCIATED TABLES     (NTMUA) :      0
 NUMBER OF WORDS OF THE MATRIX          (LMUA5) :   737202
 MAX DIFFERENCE BETWEEN 2 NODES OF AN ELEMENT    (LBDP) :       70
 MAX DIFFERENCE BETWEEN 2 D.O.F. OF AN ELEMENT (LBDPDL) :      210
 MAX NUMBER OF NODES PER ELEMENT       (NNOMAX) :        8
 NUMBER OF RHS VECTORS                   (NDSM) :        1
 NUMBER OF WORDS IN C.M. FOR D.S. NDL1 (MCNDL1) :        0
 NUMBER OF WORDS IN C.M. FOR D.S. MUA   (MCMUA) :   740060
 NUMBER OF WORDS IN C.M. FOR D.S. B       (MCB) :     5667
 END OF MODULE PREPAC
 MODULE ASSMUA :
 ARRAY OF TAE TO ASSEMBLE         (NOT) :     1
 INPUT D.S. TAE       (NFTAE AND NITAE) :     12     1
 INPUT D.S. NDL1    (NFNDL1 AND NINDL1) :      0     0
 INPUT D.S. MUA     (NFMUAE AND NIMUAE) :      0     0
 OUTPUT D.S. MUA    (NFMUAS AND NIMUAS) :      0     0
 ASSEMBLY OF ELEMENT ARRAY    1 HAS    1 INDEX(CES), WITH STORAGE CODE    1
 STORAGE CODE OF THE GLOBAL MATRIX      1
 END OF MODULE ASSMUA
 MODULE ASEMBV :
 ARRAY TO ASSEMBLE              (NOT) :      2
 OUTPUT D.S. B          (NFB AND NIB) :      0     1
 NUMBER OF ASSOCIATED TABLES    (NTB) :      0
 NUMBER OF WORDS IN CENTRAL MEMORY FOR THE D.S. B :    5667
 END OF MODULE ASEMBV
 PROCESSING OPTION            (NIVO) :      3
 PENALTY VALUE                 (VTG) :    1.000000
 INPUT D.S. NDL1 (NFNDL1 ET NINDL1 ) :      0     0
 INPUT D.S. MUA  (NFMUAE ET NIMUAE ) :      0     0
 INPUT D.S. B    (NFBE   ET NIBE   ) :      0     1
 INPUT D.S. BDCL (NFBDCL ET NIBDCL ) :     13     1
 OUTPUT D.S. MUA (NFMUAS ET NIMUAS ) :      0     0
 OUTPUT D.S. B   (NFBS   ET NIBS   ) :      0     1
 END OF MODULE CLIMPC
 MODULE CHOLPC :
 PRECISION                    (EPS) :   0.1000000E-14
 RETURN OPTION             (NENTRE) :     0
 INPUT D.S. MUA  (NFMUAE ET NIMUAE) :     0     0
 OUTPUT D.S. MUA (NFMUAS ET NIMUAS) :     0     0
 ** FACTORISATION EXECUTION TIME               0.504265E+02 S **
 END OF MODULE CHOLPC
 MODULE DRCHPC :
 PROCESSING OPTION                     (NIVEAU) :      3
 PRESENCE OF BOUNDARY CONDITIONS IN L.R. (NCLRL) :      0
 INPUT D.S. B                   (NFBE AND NIBE) :      0     1
 INPUT D.S. BDCL            (NFBDCL AND NIBDCL) :     13     1
 OUTPUT D.S. B                  (NFBS AND NIBS) :     14     1
 ** RESOLUTION EXECUTION TIME                  0.382422E+01 S **
 END OF MODULE DRCHPC
     PRINT OUT OF D.S. B    OF LEVEL  1
 TITLE                           :
 DATE AND USER'S NAME            : 06/05/93  pate
 DATA STRUCTURE TYPE             : B
 LEVEL AND STATE NUMBER          :      1     2
 NUMBER OF ASSOCIATED TABLES     :      0
 TABLE  B 2
 TYPE OF THE TABLE                           (NTYT) :      5
 NUMBER OF INDICES AND THEIR MAX VALUES    (NIND..) :      2     1  2811
 OPTION (1: PAGES OF SAME SIZE , 0: IF NOT)  (NCOD) :      1
 NUMBER OF PAGES OF THE TABLE B4            (NBLOC) :      1
 NUMBER OF NODES                              (NOE) :    937
 NUMBER OF TABLES B4 IN THIS D.S.          (NBBLOC) :      1
 CONSTANT NUMBER OF D.O.F. AT EACH NODE OR 0   (ND) :      3
 NUMBER OF D.O.F. OR LENGHT OF A B4 PAGE     (NTDL) :   2811
 STORAGE OPTION FOR B4                     (NCODSB) :     -1
 TABLE  B 3
  POINTER ON THE LAST ROW OF EACH PAGE OF B4
     1           0     2        2811
F
1.2.2 Solution by Crout in main memory
Main program CROUXX successively calls modules PREPAC, ASSMUA, ASEMBV, CROUPC and, lastly, DRCRPC. The listing of the data of CROUXX is shown below:
 crochet.mail                          $ FILE NAME
 crochet.tae                           $ FILE NAME
     1                                 $ 1 IF BDCL EIS USED , 0 IF NOT
 crochet.bdcl                          $ FILE NAME
     0                                 $ 1 IF B.C. EXIST AS L.R
 crochet.b                             $ FILE NAME
     3                                 $ IMPREB
The corresponding results are given below:
 DATE   : 14/06/93
 AUTEUR : dutoit
 EXECUTING THE CROUT SOLUTION METHOD WITH SEQUENTIAL FILES
E
dcrou.data_gb
3
 ++ OPEN(14,FILE='crochet.bcrou',SPEC='UNFORMATTED',RECL=0)
 MODULE PREPAC :
 MODULE ASSMUA :
 MODULE ASEMBV :
 MODULE CROUPC :
 PRECISION OF MEMORY WORD  (EPS) :   0.1000000E-14
 IDS NDL1    (NFNDL1 AND NINDL1) :     0     0
 IDS MUA     (NFMUAE AND NIMUAE) :     0     0
 IDS MUA     (NFMUAS AND NIMUAS) :     0     0
 ** FACTORISATION EXECUTION TIME               0.884851E+02 S **
 END OF MODULE CROUPC
 MODULE DRCRPC :
 ** RESOLUTION EXECUTION TIME                  0.224702E+01 S **
 END OF  MODULE DRCRPC
 TITLE                           :
 TABLE  B 2
 TABLE  B 3
     1           0     2        2811
F
1.2.3 Solution by Cholesky in secondary memory
Since the memory space required to store this matrix is quite large, it is advantageous to use module CHOLPS where the matrix is stored in secondary memory. Main program CHOSXX successively calls modules PREPAC, ASMAPS, ASMBMS CHOLPS and, lastly, DRCHPS. The listing of the data of CHOSXX is given below:
 crochet.mua                        $ FILE NAME
     1                              $     AND LEVEL OF THE D.S.  MUA
     4                              $ IMPREB
  4096                              $ LPAGE
 DATE   : 15/06/93
 AUTEUR : dutoit
E
dchos.data-gb
3
 MODULE PREPAC :
 lpage  =  4096
 nbpag =  6
 ++ OPEN(14,FILE='mua',SPEC='DIRECT',RECL=16384)
 ++ OPEN(15,FILE='crochet.bchos',SPEC='DIRECT',RECL=16384)
 MODULE PREPAC :
 OUTPUT D.S. MUA      (NFMUA  ET NIMUA ) :    -14     1
 NUMBER OF WORDS IN C.M. FOR D.S. MUA   (MCMUA) :   740247
 MODULE ASMAPS :
 ARRAY TAE TO ASSEMBLE        (NOT) :     1
 I.D.S. TAE      (NFTAE AND NITAE ) :     12     1
 O.D.S. NDL1    (NFNDL1 AND NINDL1) :      0     0
 O.D.S. MUA     (NFMUAE AND NIMUAE) :    -14     0
 O.D.S. MUA     (NFMUAS AND NIMUAS) :    -14     0
 ASSEMBLY OF ELEMENT ARRAY    1 WITH    1   INDEX(S),
 WITH STORAGE CODE    1
 STORAGE CODE OF GLOBAL MATRIX      1
 SP INITMP : NUMBER OF PAGES IN MAIN MEMORY :     35
 NUMBER OF WORDS IN MAIN MEMORY OF MUA   7141
 END OF MODULE ASMAPS
 MODULE ASMBMS :
 ARRAY TAE TO ASSEMBLE        (NOT) :      2
 I.D.S. NDL1     (NFNDL1 ET NINDL1) :      0     0
 O.D.S. B        (NFB    ET NIB   ) :    -15     1
 SP INITMP : NUMBER OF PAGES IN MAIN MEMORY :      2
 WITH STORAGE CODE    1
 STORAGE CODE OF RIGHT HAND SIDE   -1
 NUMBER OF WORDS IN CENTRAL MEMORY FOR THE D.S. B :    4142
 FIN DU MODULE ASMBMS
 MODULE CLIMPS :
 INPUT D.S. MUA             (NFMUAE AND NIMUAE) :    -14     0
 INPUT D.S. B                   (NFBE AND NIBE) :    -15     1
 INPUT D.S. MUA             (NFMUAS AND NIMUAS) :    -14     0
 OUTPUT D.S. B                  (NFBS AND NIBS) :    -15     1
 END OF MODULE CLIMPS
 MODULE CHOLPS :
 INPUT D.S. MUA  (NFMUAE ET NIMUAE) :   -14     0
 OUTPUT D.S. MUA (NFMUAS ET NIMUAS) :   -14     0
 ** FACTORISATION EXECUTION TIME               0.996348E+02 S **
 MODULE DRCHPS :
 ** SOLUTION EXECUTION TIME                    0.267583E+02 S **
 TITLE                           :
 DATE AND USER'S NAME            : 09/07/93  pate
 TABLE  B 2
 NUMBER OF INDICES AND THEIR MAX VALUES    (NIND..) :      2     1  2048
 NUMBER OF PAGES OF THE TABLE B4            (NBLOC) :      2
 TABLE  B 3
     1           0     2        2048     3        2811
F
1.2.4 Solution by frontal Cholesky
The optimization of memory space is accomplished by the frontal method, which manages this resource to the best, by storing only the indispensable rows of the linear system.
Main program FRONXX successively calls modules PREPAF and FRONT. The listing of the data of FRONXX is shown below:
 mail                               $ FILE NAME
 tae                                $ FILE NAME
     1                              $ 1 IF BOUNDARY CONDITIONS I.T.O.
 bdcl                               $ FILE NAME
 crochet.bfron                                  $ FILE NAME
     3                              $ IMPREB
      2                             $ INCREASE OF THE NUMBER OF FRONTS
The corresponding results are given below. Files fron and gaus are temporary files used by modules PREPAF and FRONT.
 DATE   : 15/06/93
 AUTEUR : dutoit
 EXECUTION OF THE FRONTAL SOLUTION METHOD WITH SEQUENTIAL FILES
E
dfron.data_gb
3
 ++ OPEN(14,FILE='crochet.bfron',SPEC='UNFORMATTED',RECL=0)
 ++ OPEN(15,FILE='',SPEC='SCRATCH,UNFORMATTED',RECL=0)
 ++ OPEN(16,FILE='',SPEC='SCRATCH,UNFORMATTED',RECL=0)
 MODULE PREPAF :
 MAXIMUM NUMBER OF NODES IN AN ELEMENT (NNOMAX)  :      8
 CONSTANT NUMBER OF D.O.F. PER NODES (OR 0) (ND) :      3
 MAXIMUM NUMBER OF D.O.F. AT A NODE     (NDLMAX) :      3
 TOTAL NUMBER OF FRONTS                 (NTYPFR) :      1
 NUMBER OF D.O.F. PER FRONT  :
             FRONT NUMBER      1 :      3
 NUMBER OF ELEMENTS :   1006
 NUMBER OF NODES    :    937
 NUMBER OF FRONTS   :      1
 LENGTH OF FRONT EXPECTED ( FOR ANY TYPE OF FRONT ) :    937
 FRONT NUMBER :      1  (NODES SUPPORTING   3 D.O.F.)
 LENGTH OF FRONT :    242
 NUMBER OF DEGREES OF FREEDOM OF SYSTEM         :   2811
 NUMBER OF DEGREES OF FREEDOM OF FRONTAL SYSTEM :    726
 SIZE OF NON-SYMMETRIC FRONTAL MATRIX           : 527076
 SIZE OF SYMMETRIC FRONTAL MATRIX               : 263901
 SIZE OF FRONTAL R.H.S.                         :    726
 ** PREPARATION EXECUTION TIME                 0.166020E+01 S **
 END OF MODULE PREPAF
 MODULE FRONT  :
 SOLUTION OF A SYMMETRIC SYSTEM
 TOTAL NO OF ELEMENTSB    1006
 TOTAL NUMBER OF NODES      937
 RANK OF SYSTEM           726
 NUMBER OF R.H.S.     1
 ** RESOLUTION EXECUTION TIME                  0.780065E+03 S **
 END OF MODULE FRONT
 TITLE                           :
 LEVEL AND STATE NUMBER          :      1     0
 TABLE  B 2
 TABLE  B 3
     1           0     2        2811
F
1.2.5 Solution by Conjugate Gradient
If we want to solve the model problem by the conjugate gradient method, we need to assemble the matrix in a compact form, an AMAT data structure. Module GRADXX successively calls modules PREPGC, ASSAMA, ASEMBV, then depending on the type of preconditioning chosen, one of the following modules:
The model problem is firstly solved by conjugate gradient iterations without preconditioning (module SIMPGC), using the following data:
 crochet.nopo                          $ FILE NAME
     1                                 $     AND LEVEL OF THE D.S. NOPO
     1                                 $ 1 IF BDCL EXISTS
                                       $ I.T.O. LINEAR RELATIONS EXIST
     3                                 $ PRINT PARAMETER
     0                                 $ METHOD
  0.1000000E-03                        $ EPS
 DATE   : 18/06/93
 AUTEUR : dutoit
 EXECUTING OF CONJUGATE GRADIENT SOLUTION WITH SEQUENTIAL FILES
E
dgrad.data_gb
 --PRINT PARAMETER FOR EXECUTION ?
3
 ++ OPEN(11,FILE='nopo',SPEC='OLD,UNFORMATTED',RECL=0)
 ++ OPEN(14,FILE='crochet.bgrad',SPEC='UNFORMATTED',RECL=0)
 MODULE PREPGC :
 MATRIX STRORAGE CODE           (NCODSA) :      1
 ARRAY TYPE                        (NTY) :      5
 INPUT D.S. NOPO     (NFNOPO AND NINOPO) :     11     1
 OUTPUT D.S. AMAT    (NFAMAT AND NIAMAT) :      0     0
 NUMBER OF ASSOCIATED TABLES    (NTAMAT) :      0
 NUMBER OF WORDS IN C.M. OF THE ASSEMBLED D.S. AMAT :     198030
 END OF MODULE PREPGC
 MODULE ASSAMA :
 INPUT D.S. AMAT  (NFAMAT AND NIAMAT) :      0     0
 INPUT D.S. TAE   (NFTAE  AND NITAE ) :     12     1
 ASSEMBLY OF ELEMENT ARRAY    1 HAS    1 INDEX(ES), OF STORAGE CODE    1
 STORAGE CODE FOR THE GLOBAL MATRIX      1
 END OF MODULE ASSAMA
 MODULE ASEMBV :
 MODULE CLIMGC :
 INPUT D.S. NDL1  (NFNDL1 AND NINDL1 ) :      0     0
 INPUT D.S. AMAT  (NFAMAT AND NIAMAT ) :      0     0
 INPUT D.S. B     (NFBE   AND NIBE   ) :      0     1
 INPUT D.S. BDCL  (NFBDCL AND NIBDCL ) :     13     1
 OUTPUT D.S. AMAT (NFAMAT AND NIAMAT ) :      0     0
 OUTPUT D.S. B    (NFBS   AND NIBS   ) :      0     1
 END OF MODULE CLIMGC
 MODULE SIMPGC :
 STOP PARAMETER                   (EPS) :  0.100000E-03
 NAME OF INITIALISATION ARRAY           : NULL
 NUMBER OF LINEAR COMBINATIONS  (NCLRL) :      0
 I.D.S. BDCL        (NFBDCL AND NIBDCL) :     13     1
 I.D.S. B           (NFBE   AND NIBE  ) :      0     1
 I.D.S. AMAT        (NFAMAT AND NIAMAT) :      0     0
 O.D.S. B           (NFBS   AND NIBS  ) :     14     1
 INITIALISATION OF C.G. TO ZERO
 SYSTEM NUMBER :      1
 NORM OF B :  0.229213E+09 MAXIMUM NUMBER OF ITERATIONS :   2811
 STOP TEST (EPS1) :   2.29213
 NUMBER OF ITERATIONS OF SYSTEM NUMBER     1 :    1211
 ** RESOLUTION EXECUTION TIME                  0.432811E+03 S **
 END OF MODULE SIMPGC
 TITLE                           :
 TABLE  B 2
 TABLE  B 3
     1           0     2        2811
f
The model problem is then solved by conjugate gradient iterations with SSOR preconditioning (module SSORGC), using the following data:
     3                                 $ PRINT PARAMETER
     1                                 $ METHOD
  0.1000000E-03    1.000000            $ EPS OMEGA
 DATE   : 18/06/93
 AUTEUR : dutoit
E
dgrad1.data_gb
3
 ++ OPEN(14,FILE='crochet.bsor',SPEC='UNFORMATTED',RECL=0)
 MODULE PREPGC :
 MODULE ASSAMA :
 MODULE ASEMBV :
 MODULE CLIMGC :
 MODULE SSORGC :
 RELAXATION PARAMETER            (OMEGA) :   1.00000
 SYSTEM NUMBER :      1
 OMEGA :   1.00000     NORM OF B :  0.229213E+09 MAXIMUM NUMBER OF ITERATIONS :   1405
 NUMBER OF ITERATIONS OF SYSTEM NUMBER    1 :     231
 ** RESOLUTION EXECUTION TIME                  0.163186E+03 S **
  END OF MODULE SSORGC
 TITLE                           :
 TABLE  B 2
 TABLE  B 3
     1           0     2        2811
f
Lastly, the model problem is solved by conjugate gradient iterations with preconditioning by incomplete Cholesky factorisation by level (module ICHRGC). We use an incomplete factorisation of level 0, and the preconditioning matrix is compressed using module CCAMAT, with a sort coefficient equal to .
     3                                 $ PRINT PARAMETER
     2                                 $ METHOD
     1                                 $ FACTORISATION
     1   0.1000000E-04                 $ 1 IF COMPRESSION RATIO
  0.1000000E-03                        $ EPS
The results corresponding to the last method is given below:
 DATE   : 18/06/93
 AUTEUR : dutoit
e
dgrad2.data-gb
3
 ++ OPEN(14,FILE='crochet.bich',SPEC='UNFORMATTED',RECL=0)
 MODULE PREPGC :
 MODULE ASSAMA :
 MODULE ASEMBV :
 MODULE CLIMGC :
 MODULE FANIGC :
 CHOLESKY INCOMPLETE FACTORISATION      :      1
 OUTPUT D.S. AMAT   (NFAMAT AND NIAMAT) :      0     1
 LEVEL OF FILL-IN                       :      0
 NUMBER OF UNKNOWNS                         2811
 NUMBER OF NONZEROS  OF A                  65058
 INCOMPLETE FACTORISATION  AT LEVEL            0
 NUMBER OF  NONZEROS OF CA                 65058
 **  FACTORISATION CPU TIME                    0.400442E+01 SECONDS  **
 END OF MODULE FANIGC
 MODULE CCAMAT :
 COMPRESSION RATIO       (RAPORT) :  0.100000E-04
 I.D.S AMAT  (NFAMAT AND NIAMAT ) :      0     1
 O.D.S. AMAT (NFAMAT AND NIAMAT ) :      0     1
 NUMBER OF COEFFICIENTS ELIMINATED :       9724
 END OF MODULE CCAMAT
 MODULE ICHRGC :
 TERMINATION PARAMETER            (EPS) :  0.100000E-03
 INPUT D.S. AMAT    (NFAMAC AND NIAMAC) :      0     1
 OUTPUT D.S. B      (NFBS   AND NIBS  ) :     14     1
 FACTORISATION :  1 CHOLESKY, 2 CROUT (NFACTO) :      1
 INITIALISATION OF CONJUGATE GRADIENT TO ZERO
 SYSTEM NUMBER :      1
 NUMBER OF ITERATIONS OF SYSTEM NUMBER     1 :      80
 ** RESOLUTION EXECUTION TIME                  0.523324E+02 S **
 END OF MODULE ICHRGC
 TITLE                           :
 LEVEL AND STATE NUMBER          :      1     1
 TABLE  B 2
 TABLE  B 3
     1           0     2        2811
f
