Next: 8.2 Adapting a new output terminal
Up: 8 Adapting a new terminal
Prev: 8 Adapting a new terminal
Contents
The link between FORTRAN 3D and the input terminals is made through two intermediary subroutines PERFGN and ITRCTG.
Subroutine PERFGN will be defined in the next section. Subroutine ITRCTG is constructed as follows:
ITRCTG : ------ SUBROUTINE ITRCTG(INSTRU, T1, T2, T3, IT1, IT2, IT3, STRING) CHARACTER *(*)STRING REAL T1(*), T2(*), T3(*) INTEGER IT1(*), IT2(*), IT3(*) include 'data_f3d.ins' GOTO(1 , 2, 3, 4, 5, 6, 7, 8, 9, 10 , 11), IDEVIN C CALL ITRCTX(INSTRU, T1, T2, T3, IT1, IT2, IT3, STRING) RETURN 001 CONTINUE C APOLLO CALL ITRCT5(INSTRU, T1, T2, T3, IT1, IT2, IT3, STRING) RETURN 002 CONTINUE C LASER_WRITER(POST_SCRIPT) CALL ITRCTX(INSTRU, T1, T2, T3, IT1, IT2, IT3, STRING) RETURN 003 CONTINUE C X_WINDOW_V11 CALL ITRCTX11(INSTRU, T1, T2, T3, IT1, IT2, IT3, STRING) RETURN 004 CONTINUE C TEKTRONIX_4014 CALL ITRCT1(INSTRU, T1, T2, T3, IT1, IT2, IT3, STRING) RETURN 005 CONTINUE C APOLLO_5 CALL ITRCT5(INSTRU, T1, T2, T3, IT1, IT2, IT3, STRING) RETURN 006 CONTINUE C PRINTER CALL ITRCTX(INSTRU, T1, T2, T3, IT1, IT2, IT3, STRING) RETURN 007 CONTINUE C VERSATEK_SPECTRUM_V80 CALL ITRCTX(INSTRU, T1, T2, T3, IT1, IT2, IT3, STRING) RETURN 008 CONTINUE C VERSATEK_V80 CALL ITRCTX(INSTRU, T1, T2, T3, IT1, IT2, IT3, STRING) RETURN 009 CONTINUE C TEKTRONIX_4107 CALL ITRCTE(INSTRU, T1, T2, T3, IT1, IT2, IT3, STRING) RETURN 010 CONTINUE C TEKTRO_4105 CALL ITRCTN(INSTRU, T1, T2, T3, IT1, IT2, IT3, STRING) RETURN 011 CONTINUE C PHIGS CALL ITRPHG(INSTRU, T1, T2, T3, IT1, IT2, IT3, STRING) RETURN END
For an arbitrary driver, the parameters are:
The use of these variables depends on INSTRU (see below).
To use a graphics terminal, which is not yet offered on the MODULEF magnetic tape, the user needs to write program ITRCT* (see below) and include a call to subroutine ITRCTG in it.
Parameter INSTRU has very particular effects if it is negative:
if(INSTRU.lt.0)then {interrogation du device} if( INSTRU.eq.-1)then c print on i1= number of order call wchari(i1, 'PERIPHERIQUE XXX en entree') return elseif(INSTRU.eq.-2)then c definition of the call parameters with dialogue c we assign, using dialogue, the call parameters c that we store in IT2(1), IT2(2), ... STRING return elseif(INSTRU.eq.-3)then c default parameters (without dialogue) IT2(1)=std { type standard du curseur } return endif endif call wchari(INSTRU, ' est une valeur incomprehensible en entree') return GOTO indexe selon les valeurs >0 de INSTRU goto(1, 2, 3, 4, 5, 6, 7, 8, 9), INSTRU
The different tasks to be performed, referenced by INSTRU, are described below:
INSTRU = 1 : INITIALIZATIONS OF THE INPUT TERMINAL (DEVICI) ---------- IN : IT1 : number of the active terminal IT2(*) and STRING : supplementary information for certain terminals Initialize the values of the keys whose names are in key_board.ins c key values for APOLLO bs=char(8) cr=char(13) lf=char(10) del=char(127) mark=char(129) line_del=char(130) char_del=char(131) marg_left=char(132) cmd=char(133) marg_right=char(134) pad_left=char(135) curs_down=char(136) pad_right=char(137) curs_left=char(138) next_window=char(139) curs_right=char(140) pad_up=char(141) curs_up=char(142) pad_down=char(143) pop=char(144) again=char(145) exit=char(148) back_space=char(149) return=char(150) funct1=char(192) funct2=char(193) funct3=char(194) funct4=char(195) funct5=char(196) funct6=char(197) funct7=char(198) funct8=char(199) funct9=char(187) funct10=char(0) funct11=char(0) funct12=char(0) shell=char(205) copy=char(232) tpast=char(233) grow=char(234) hold=char(235) cut=char(236) undo=char(237) move=char(238) help=char(239) c with shift funct0=char(186) sfunct0=char(190) sfunct1=char(208) sfunct2=char(209) sfunct3=char(210) sfunct4=char(211) sfunct5=char(212) sfunct6=char(213) sfunct7=char(214) sfunct8=char(215) sfunct9=char(191) sfunct10=char(0) sfunct11=char(0) sfunct12=char(0) smarg_right=char(206) spad_left=char(207) scurs_down=char(216) spad_right=char(217) scurs_left=char(218) snext_window=char(219) scurs_right=char(220) spad_up=char(221) scurs_up=char(222) spad_down=char(219) sagain=char(181) sread=char(182) spop=char(200) INSTRU = 2 : INPUT A POSITION (GETXY) ---------- OUT : T1(1) : X in cm. T2(1) : Y in cm. INSTRU = 3 : INPUT A POSITION AND ENTER A CHARACTER (GETXYC) ---------- OUT : T1(1) : X in cm. T2(1) : Y in cm. STRING(1:1) the character entered INSTRU = 4 : INPUT A BROKEN LINE (STROKE) ---------- IN : IT1(1) number of points to input IT1(2) constraint 0 : no constraint 1 : 2 successive points on the curve input are separated by a minimum of T3(1) cm. and a maximum of T3(2) cm. OUT : IT2(1) number of points actually input T1(*) : array containing the abscissas in cm. T2(*) : array containing the coordinates in cm. INSTRU = 5 : INPUT A TEXT (GETEXT) ---------- IN : T1(1) : X in cm. of the beginning of the text T2(1) : Y in cm. of the beginning of the text STRING(1:IT1(1)) : the non-editable text to print IT1(1) : number of characters in the non-editable text to print IT2(1) : maximum number of characters IT3(1) : number of characters in the initial editable text STRING(IT1(1)+1:IT1(1)+IT3(1)) : initial editable text OUT : T3(1) : X in cm. of the end of the text T3(2) : Y in cm. of the end of the text IT3(1) : number of characters input STRING(IT1(1)+1 : IT1(1)+IT3(1)) : text input INSTRU = 6 : INPUT A NUMBER (GETNUM) ---------- IN : T1(1) : X in cm. of the beginning of the text T2(1) : Y in cm. of the beginning of the text STRING(1:IT1(1)) : the text to print IT1(1) : number of characters in the text to print IT2(1) : type of number (0 integer, 1 real, 2 boolean) IT2(2) : constraint 0 : no constraint 1 : min and max constraints for the numbers: the constraints are stored in: T3(1)=min and T3(2)=max for reals IT3(1)=min and IT3(2)=max for integers OUT : depending on type: IT3(3) the integer or boolean (0=.TRUE., 1=.FALSE.) number T3(3) the real number If the user types (return) the variables are not modified on exit. INSTRU = 7 : INPUT AN IDENTIFICATION (GETHIT) ---------- OUT : IT1(1) : number of the designated segment IT1(2) : associated value ( value given by debas(*) if not -1 ) INSTRU = 8 : DIMENSION OF THE INPUT SURFACE (SZSCRI) ---------- OUT : T1(1) : Xmin in cm. T1(2) : Xmax in cm. T1(3) : Ymin in cm. T1(4) : Ymax in cm. INSTRU = 9 : INQUIRY OF THE NUMBER OF MOUSE KEYS (INQCRC) ---------- OUT : IT1(1) : number of keys on the mouse IT2(*) : the integer codes of the keys or 0 if undefined code
Inspired by the programs already proposed, we define the different actions as a function of the possibilities offered by the graphics terminal at our disposal.
The fictitious subroutine, ITREXE, residing in library perf-example can serve as a model when creating the input program for a new device.
In addition, a certain number of subroutines were written to aid with a quick implementation of the drivers (see chapter 7 and the index):
GETUNF RCHARS RINTG RREAL CHARI WCHARS ZCENTR ZCOLOR ZFNDTC ZGNUM ZGTEXT ZSTROK ZTXT
