![[BIG]](../icons/zoom18.gif)
![[Normal]](../icons/zoom14.gif)
![[small]](../icons/zoom10.gif)
Next: 1 General structure
Up: Part II: Graphics
Prev: Part II: Graphics
Contents
Below follows a list of the preprocessor name to use as a function of the type of plot desired, followed by the
inverse listing, i.e. the type of plot possible as a function of the preprocessor name.
Plot type:
- 2D stresses: TRSTXX MAIL, COOR and TAE
- 3D stresses: not yet implemented
- Cut through a 2D solution: TRMCXX MAIL, COOR and B
- Cut through a 3D solution (simple case): COUPXX NOPO and B
- Cut through a 3D solution (general case): TRC3XX NMAIL COOR and B
- Curves Y=F(X) TRACXX file of values
- 2D and 3D deformations (simple case): TRNOXX NOPO and B
- 2D deformations (general case): TRMCXX MAIL, COOR and B
- 3D deformations (general case): TRC3XX MAIL, COOR and B
- 2D isovalues (simple case): ISOPXX NOPO and B
- 2D isovalues (general case): TRMCXX MAIL, COOR and B
- 3D isovalues (on the surface or cut): TRC3XX MAIL, COOR and B
- 2D and 3D meshes: TRNOXX NOPO or GEOM
- 3D meshes and manipulations: REFEXX NOPO or GEOM
- 2D plasticity: TRSTXX MAIL, COOR and B
- 2D characteristic points and lines: TRPOXX data of APNOXX
- Matrix profile: TRPRXX MUA or AMAT
- 2D velocity: TRMCXX MAIL, COOR and B
- 3D velocity: TRC3XX MAIL, COOR and B
- 2D piezometry (simple case): ISOPXX NOPO and B
- Surfaces Z=F(X,Y): VIS3XX NOPO and B or manual input
Preprocessor:
- TRSTXX: 2D stresses, 2D plasticity zones
- TRMCXX: 2D meshes, deformations, velocities. isovalues, cuts
- COUPXX: 3D meshes and cuts
- TRACXX: curves
- TRNOXX: 2D and 3D meshes
- TRC3XX: 3D meshes, deformations, velocities. isovalues, cuts
- REFEXX: 3D meshes and transformations
- TRPOXX: characteristic points and lines (data of APNOPO)
- TRPRXX: matrix profile
- ISOPXX: piezometry
- VIS3XX: surfaces
Contents
