Next: 6.2 Utilization
Up: 6 Diverse visualizations
Prev: 6 Diverse visualizations
Contents
The preprocessors which follow were written with the goal of obtaining plots
corresponding to particular applications.
The following possibilities are offered:
- a plot of the matrix profile (D.S. MUA or AMAT) to observe the corresponding
matrix structure;
- a plot of the characteristic points and lines described in the data file of preprocessor
APNOXX (see [MODULEF User Guide - 3]) to verify the coherence of the data;
- a plot of the isovalues of a solution (P1) on a cut plane in a 3D domain (using D.S. NOPO and B);
- a particular plot of the solutions of a flow problem in a porous medium.
Contents
