Next: 5.1 Color
Up: Part III: Fortran 3D
Prev: 4.6 Texts
Contents
The following subroutines define the graphics as well as the line segments and text aspects. Their effect is effective until the next call.
SUBROUTINE DRAW3(I) INTEGER I
SUBROUTINE THICK(EPAIS) REAL EPAIS
defines the line thickness in mm.
SUBROUTINE LIGH3(INTENS, CLIGNO, COULEU) INTEGER INTENS, CLIGNO, COULEU
where:
SUBROUTINE DRW3TX(TAILLE, SENS, POLICE) REAL TAILLE, SENS INTEGER POLICE
defines the size and orientation of the text in 2D (TXT2D) as well as in 3D (TXT3D), where:
SUBROUTINE CTRTXT(ALPHA, BETA) REAL ALPHA, BETA
defines the text frame box. The text is supposed to be in the box (0., 0.) (1., 1.).
ALPHA and BETA, lying between 0. and 1., indicate the desired centering position in this box.
SUBROUTINE LIMITS(I) INTEGER I
places the window on the screen using lines of type I (see DRAW3).
SUBROUTINE HACHUR(CONTOU,N,ANGLE,DISTAN,TYPE,EPAIS,INTENS,CLIGNO, COULEU,NMOTIF,ACTION) INTEGER NMOTIF,TYPE(NMOTIF),INTENS(NMOTIF),CLIGNO(NMOTIF), COULEU(NMOTIF) REAL CONTOU(4, N), ANGLE, DISTAN(NMOTIF), EPAIS(NMOTIF) EXTERNAL ACTION
plots the hachure , at an angle ANGLE with respect to the horizontal, in the contour defined by CONTOU.
CONTOU(4, N) defines the contour by a set of N line segments (X1, Y1)(X2, Y2) (in centimeters) where:
CONTOU(1, I) = X1 CONTOU(2, I) = Y1 CONTOU(3, I) = X2 CONTOU(4, I) = Y2
The segments do not have to be adjoining and can thus define contours with holes. The definition of the haching motifs is done by 2 types of parameters:
The I texture is plotted at distance, DISTAN(I-1), modulo NMOTIF, i.e, loop:
" Plot texture 1, move a distance DISTAN(1);
plot texture 2, move by DISTAN(2);
etc.;
plot texture NMOTIF, move DISTAN(NMOTIF);
start again ... end of loop. "
