Modulefpreviousupnextcontents[BIG][Normal][small]
Next: 2.10 Norm and residues Up: 2 Manipulation of solutions Prev: 2.8 Inquiring about D.S. Contents
2.9 Extrema of a D.S. B
Preprocessor MAXDXX is used to obtain the extreme solution values contained in a D.S. B and the d.o.f. at which these extrema occur. The module called is MAXDLB.
      SUBROUTINE MAXDLB(M,XM,DM,NFB,NIB,MAXI,NIMPR)
C  +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
C  AIM : PRINT PER LOCAL D.O.F. THE NIMPR NODES WITH THE
C  ---   OPTIMUM RESULT W.R.T. MAXI
where
