Next: 2.10 Norm and residues
Up: 2 Manipulation of solutions
Prev: 2.8 Inquiring about D.S.
Contents
Preprocessor MAXDXX is used to obtain the extreme solution values contained in a D.S. B and the d.o.f. at which these extrema occur. The module called is MAXDLB.
SUBROUTINE MAXDLB(M,XM,DM,NFB,NIB,MAXI,NIMPR) C +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ C AIM : PRINT PER LOCAL D.O.F. THE NIMPR NODES WITH THE C --- OPTIMUM RESULT W.R.T. MAXI C +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
where
