Next: 3.2 Two-dimensional solutions TRMCXX
Up: 3 Visualization of solutions
Prev: 3 Visualization of solutions
Contents
Preprocessors TRMCXX and TRC3XX call modules TRMACO (2D case) and TRMC3G (3D case) which, by using the MAIL and COOR data structures, enables the user to visualize the solution given in the form of a B structure.
Preprocessor TRSTXX calls module TRSTRE (2D case) which, by using the MAIL and COOR data structures, enables the user to visualize the stresses given in the form of a TAE structure. The latter is obtained by combining the element stresses with the solution (displacement) for an elasticity problem (see Part I of this user guide).
The modules can consider several meshes and solutions (or files) until the main memory is saturated. Numerous possibilities are offered to enables the user to:
