Next: 6.4 Characteristic points and lines TRPOXX
Up: 6 Diverse visualizations
Prev: 6.2 Utilization
Contents
Preprocessor TRPRXX is used to plot the skyline of a MUA type matrix, skyline storage, or a AMAT type matrix, compact storage.
The plot consists of placing a small cross (or square) at each coefficient position of a non-zero value. This positions are determined using the row and column indices of the coefficients.
The menu of TRAKOU (module called in this case) is given below:
------------------------------------------------------------ | 11 | DEVICE NUMBER | 1 ------------------------------------------------------------ | 20 | FILE CONTAINING THE D.S. | t2mua ------------------------------------------------------------ | | LINES'S EXTREMA | 0.0000000 370.0000 ------------------------------------------------------------ | 21 | EXTREMA FOR X AXIS | 0.0000000 370.0000 ------------------------------------------------------------ | | EXTREMA OF COLUMNS | -370.0000 0.0000000 ------------------------------------------------------------ | 21 | EXTREMA FOR Y AXIS | -370.0000 0.0000000 ------------------------------------------------------------ | 30 | PLOT SIZE | AUTO ------------------------------------------------------------ | 40 | SYMBOLS USED | CROIX ------------------------------------------------------------ | 60 | GENERAL LEGEND | YES ------------------------------------------------------------ | 81 | LINE THICKNESS | 1 ------------------------------------------------------------
A default value is proposed for each option. The above table lists the selections made automatically. Type 0 to obtain a plot.
A key (a number) and a status correspond to each item. To modify the status, it suffices to type the key and enter the values corresponding to the status desired (see the general introduction). The list of keys is given below:
Once a plot is displayed on the screen, a graphics menu appears which is analogous to that of TRACXX, to which the user is referred.
The plot was obtained by typing the following sequence:
Figure 6.1: Example TRPRXX: matrix profile (automatic mode)
