Next: 6.5 Diverse
Up: 6 Diverse visualizations
Prev: 6.3 Matrix profiles TRPRXX
Contents
Preprocessor TRPOXX is used to plot the characteristic points and lines described in a data file of module APNOPO (see [MODULEF User Guide - 3]). This type of visualization enables the user to detect, for certain cases, errors at the data level.
The plot consists of plotting, at the characteristic points:
The menu of TRPOIN (module called in this case) is shown below:
------------------------------------------------------------------------------ | 10 | PLOT TYPE | CHARACTERISTIC POINTS ------------------------------------------------------------------------------ | 11 | DEVICE NUMBER | 1 ------------------------------------------------------------------------------ | 20 | DATA FILE | ~/latex/guide6/d2nopo.d ------------------------------------------------------------------------------ | 30 | PLOT SIZE | AUTO ------------------------------------------------------------------------------ | 40 | CHARACTER TYPE | HARD ------------------------------------------------------------------------------ | 50 | ITEMS TO PLOT | POINTS ( SYMBOL ) ------------------------------------------------------------------------------ | 60 | LEGEND | YES ------------------------------------------------------------------------------
A default value is proposed for each option. The above table lists the selections made automatically. To obtain a plot corresponding to this state, type 0.
A key (a number) and a status correspond to each item. To modify the status, it suffices to type the key and enter the values corresponding to the status desired (see the general introduction). The list of keys is given below:
POINTS ( SYMBOL ) : 1 POINTS ( WITH NUMBERS ) : 2 POINTS ( WITH REFERENCES ) : 3 LIGNES : 4 LINES ( WITH NUMBERS ) : 5 LINES ( WITH REFERENCES ) : 6 LINES AND POINTS : 7 LINES AND POINTS ( NUMBER ) : 8 LINES AND POINTS ( REFERENCES ) : 9
Once a plot is displayed on the screen, a graphics menu appears which is analogous to preceding ones except fro option 7:
The plot was obtained by typing the following sequence:
Figure 6.2: Example TRPOXX: zoom in on the characteristic points
Figure 6.3: Example TRPOXX: numbers of the characteristic lines
