The MODULEF library, based on the finite element method, enables numerous researchers, from university as well as from industry, to solve application problems such as: mesh generating, solution of time-dependent heat transfer problems, dynamic problems, eigenvalue problems, incompressible and compressible viscous fluid flow, non-linear problems, plate problems, etc.
Taking the interest in the MODULEF club into account, as much as in the industrial as in the university environment, the MODULEF library is fast becoming a complete, reliable and easy-to-use library of modules and programs to solve more and more diverse problems.
