Scilab Function
fr - eng
add_palette - Add Scicos palette
Module
Description
Add a palette to the end of the list of the scicos palette. If the palette exists with same title and same path noting is done. If a palette with same name but different path exist then the palette is added with a suffixe (x) Note that scicos_pal variable is locally recreated and passed to the upper environnement via scicos_pal=resume(scicos_pal)
Calling Sequence
add_palette(Title,path)
Parameters
File content
