Next: 1.5.8 Internal data structure
Up: The EMC˛
preprocessor
Prev: 1.5.6 Example
Index
Contents
traceNNN.emc2_trace | Trace of operations (automatically generated names). |
xx.emc2_trace | Trace of operations (name given by the user). |
xx.emc2_bd | Save under CONSTRUCTION or under PREP MESH |
xx_bak.emc2_bd | .bak file of the previous one. |
xx.data | File for the APNOPO module (it will generate xx.nopo). |
xx.nopo | File generated by EDIT MESH. |
xx.mesh | File generated by EDIT MESH. |
xx.am | File generated by EDIT MESH. |
xx.am_fmt | File generated by EDIT MESH. |
xx.ambda | File generated by EDIT MESH. |
xx.set | For linking with the VISIL software. |
xx.bas | For linking with the VISIL software. |
All those variables are initialized by program emc2.f (directory ppal), except MXNOD and MXPDEF, which are initialized in include file emc2_commons_g.ins in directory include.
