Modulefpreviousupnextcontentsindex[BIG][Normal][small]
Next: 1.5.3 The construction application Up: The EMC˛ preprocessor Prev: 1.5.1 General remarks Index Contents
1.5.2 The global menus
Using the menus the user creates, edits, destructs and so on objects stored in two databases (DB), one for the geometry and the other for meshes.
Selection menus
   These menus, shown at the bottom of the graphics window, make it possible to select the type of graphics selection we want (a point, a straight line, etc.). They depend on the application currently being used (cf. figures 1.18, 1.19, 1.20). It is absolutely essential to understand the outputs of these menus because all the rest depends on their functioning. All these outputs, for example, a circle, a number or the extremity of an arc, are marked (?) and the marks (or types ?) define the selection syntactical entities known by the grammars which manage the three applications.
Figure 1.18: The select menu for the CONSTRUCTION application
Figure: The select menu for the PREP_MESH application
Figure: The select menu for the EDIT_MESH application
The constructible types are :
These menus depend on the application being used as they define the type of element to be selected. The menu ITEMs  (their keyboard shortcut  is in parenthesis) can be classified in several categories.
  1. the items POINT (p), STRT LINE (l), CIRCLE (c), ARC (a), SEGMENT (s),
    [4] SPLINE (~) are used to select the element of the DB          closest to the clicked point, the type of selection depends on the kind of element found and by the item in categories (4), (5) that is used. If there is an incompatibility, the item in category (4) is forced to change to(?) NEAREST.
  2. The items MOUSE P  (m), XY POINT  (x), XY FILE   (<) are used to enter current points respectively as follows:
    Note: in the last two cases the point created can be outside the graphic window;
  3. the ANY  (q) item has no effect on the selection: the element of the DB closest to the clicked point is selected. The type of selection depends on the kind element found and by the item in categories 4, 5 that is used.
  4. the NEAREST  ( n)item is used to effectively select an element of the DB and the type of selection is that of the element.
  5. the EXTREM(ITY)  ( e), CENTER  ( c), MIDDLE  ( m) items are used to define what we are going to select in the element of the DB (cf. (1) and (3)), i.e., we select the point (selection type COORD) that is respectively the extremity, the center or the middle of the selected DB element, if this makes sense. Otherwise, the main mode of selection is forced to change to ANY, cf. 3. while keeping the item in category 5.
  6. the INTERSECTION (i) item is used to select the current point which is the intersection of 2 elements of the DB selected in the next paragraph (the selection type generated is COORD).
  7. the ELEMENT (f), EDGE (d), VERTEX (v), S_DOM (r) items are used to select respectively the element---either triangle or quadrangle---containing the clicked point, this is for the selection type ELEMENT, the edge in an element closest to the clicked point, this is for the selection type EDGE, , the vertex in an element closest to the clicked point, this is for the selection type VERTEX or the subdomain containing the clicked point, this is for the selection type S_DOM.
Important note: In effect, the selection only becomes effective after we have clicked on an element in the graphic window. It is possible to click in the menu items as many times as we want so as to obtain a combination of marked items. A selection defines the type of selection and it preserves the cursor coordinates at the instant of the click. These coordinates are often useful for the application being used to remove semantic ambiguities or choose between multiple solutions to the problem being treated. For example,
If we try to select something that does not exist, we get the message you have selected nothing, which has no effect whatsoever.
The selections possible depend on the application since all types of selection are not always needed. For example, circles and straight lines are only used in the CONSTRUCTION application, elements, edges, vertices and subdomains only exist in the EDIT_MESH application.
Shortcuts
Keyboard shortcuts  that correspond to ITEMs of categories 1,2,3,4,7 are equivalent to 2 clicks, the first in the ITEM box and the following on the cursor point if it is in the graphic window. Thus the mode of selection has now changed and it is the element closest to the cursor which is selected.
Practical utilization
An element is selected by clicking next to it (the program searches for the element closest to the click). When we click a menu, it is marked with a > sign in front of the text of the menu. In the selection menus, two boxes can be marked at the same time according to the following combinations:
item (shortcut) ( possible combinations)
ANY (q) ( NEAREST, EXTREMITY, CENTER, MIDDLE )
POINT (p) ( NEAREST)
STRT LINE (l) ( NEAREST)
CIRCLE (c) ( NEAREST, CENTER )
ARC (a) ( NEAREST, EXTREMITY, CENTER, MIDDLE )
SEGMENT (s) ( NEAREST, EXTREMITY, MIDDLE )
SPLINE (~) ( NEAREST, EXTREMITY )
MOUSE P (m) ( NEAREST)
XY POINT (x) ( NEAREST)
VERTEX (v) ( NEAREST)
EDGE (d) ( NEAREST)
ELEMENT (f) ( NEAREST)
S_DOM (r) ( NEAREST)
Other combinations are not valid. A selection is not effective except when an element on the screen has been clicked. In fact the boxes may be clicked as many times as necessary to obtain the desired combination.
The calculator menu
   This menu (cf. figure 1.21)  can also be considered as a selection menu. It can be used to define a numerical value which is of type <VALUE>  .
Figure 1.21: The two calculator menus
We can write any FORTRAN expression. The effective computation is achieved by clicking on the = box (shortcut =) or by typing (CR)  .
The ITEMs with their keyboard shorcut  between parentheses are:
Cell shortcut Comment
1  (1) numbers
2  (2)
3  (3)
4  (4)
5  (5)
6  (6)
7  (7)
8  (8)
9  (9)
.  (.) decimal point
,  (,) comma, separator for function arguments
|  (|) exponentiation operator
PI  =
Y  = 0
NO  = 1
E  (E) exponent for numbers in exponential format
C  (Z) resets the calculator accumulator
AC  (R) resets the calculator
Ra  = radius of a selected element (ARC or CIRCLE)
Ag  = angle of a selected element (ARC)
or angle between two STRT LINE
Lg  = length of a selected element (ARC or SEGMENT
or SPLINE).
Di  = distance between a POINT and another POINT, a STRT LINE, a CIRCLE or an ARC;
or distance between two parallel STRT LINE;
or distance between two CIRCLE.
POP   used to display the calulator menu of FORTRAN functions SIN  , COS  , TAN  , ASIN  , ACOS  , ATAN  , ATAN2 , EXP  , LOG  , LOG10 , INT  , NINT  , MOD  .
Examples: to enter
1.234567E9
type 1.234567E9(CR)
0.5
type 1/2=
3.14159...
click the PI box and type (CR)
2circle radius
type 2*, click the Ra box, then select the circle (by clicking the circle box of the selection menu then clicking near the circle in the graphic window) and finally type (CR)  .
The general menu
  This menu (cf. figure 1.22) is used to perform general operations: move between CONSTRUCTION, PREP_MESH and EDIT_MESH, save, restore, screen copy or execute a system command. To initiate an operation, click in the corresponding item.
Figure 1.22: The general menu
The operations of the general menu are:
Exiting the program
QUIT
  Terminates the execution of the program.
Querying the database
QUERY
  Queries the selected elements. Their characteristics are displayed in the input-output or scratch zone.
Destructing elements of the database
DESTRUCT
  Only available in the CONSTRUCTION application. Destructs selected elements of the database. Warning: if we destruct a POINT, the program checks if this POINT is used to define a SPLINE. If this is the case, it is also removed from the SPLINE.
Saving the database
SAVE
  Saves the DB  in a file. The name of the file is composed a prefix and a suffix. The system asks for the prefix in the scratch zone (figure 1.9). According to the case, the suffix can be .emc2_bd, .mesh, .nopo, .am, .am_fmt, .amdba and it depends on the current application:
Restoring the database
RESTORE
  Restores the DB of a file. The name of the file is composed of a prefix and a suffix. The system asks for the prefix in the scratch zone (figure 1.9). According to the case, the suffix can be .emc2_bd, .mesh, .nopo, .am, .am_fmt, .amdba. The data restored depend on the current application.
Resetting
DB_RESET
  Clears everything stored in the 2 databases.
Printing the screen
HARD_COPY
  Makes a bitmap, screen resolution, hard copy of the screen. Depends on the system and on the environment (cf. hardcp  subroutine).
Redrawing the window on another graphic peripheral device
SOFT_COPY
  Displays the screen on another Fortran 3d peripheral device. Depends on the system and on the environment (cf. softcp  subroutine)
Executing a system command
SHELL
  Executes a system command  (shell). The system asks for the the command(s) in a character string. Depends on the system (cf. exec  subroutine).
Saving a run
LOG FILE
   Saves all user operations in a file. The file name is composed of prefix given by the user and the suffix .trace_emc2. If the prefix starts with a + sign, it is appended to the trace file. A default trace file is open. Its prefix is tracexxxx, where xxxx is a version number in order not to erase the previous trace.
Reexecuting a run
INTERPRET
  Interprets a trace file. The prefix is given by the user.
Moving to the CONSTRUCTION application
CONSTRUCTION
Moves to the CONSTRUCTION  application. After the move, the selection mode is MOUSE P.
Moving to the PREP_MESH application
PREP_MESH
  Moves to the PREP_MESH application. After the move, the selection mode is MOUSE P.
Moving to the EDIT_MESH application
EDIT_MESH
  Moves to the EDIT_MESH application. When the move occurs and after the 4 questions have been answered, the program triangulates all the defined domains. If no domain has been defined, everything is meshed. The triangulation depends on 4 parameters. To get the default value, type (CR)
for each parameter.
  1. a debug parameter (default=0) that defines two other parameters:
  2. a puis parameter of refinement depth. The smaller puis is, the larger will refinement zones develop. puis = .25 is the default value. Reasonable values are between .1 and 10.
  3. a coef parameter of triangle density. The number of triangles generated is in . coef = .75 is the default value.
  4. furthermore, the system asks whether a regularization is to be applied (default is yes);
The screen management menu
  The screen management menu is shown in figure 1.23. It is present in all applications. It is used to handle the display of both databases. The display context consists in storing a display mask . This mask is a rectangle in subject space, computed so as to preserve the same scales  in X and Y. The display context stack is in fact an 8 level circular stack. It is initialized as: scale 1, mask centered at the origin.
Figure 1.23: The screen management menu
The operations of the screen management menu are:
Enlarging the display
  ZOOM + COORD COORD
The rectangle defined by the two COORD is displayed full screen. The new display context is stacked in the display stack. In general, we click two times to define two opposite corners of the rectangle.
Reducing the display
  ZOOM - COORD COORD
The contents of the full screen is displayed in the rectangle defined by the two COORD. The new display context is stacked in the display stack.
Translating the graphic window
  TRANSLATION COORD COORD
Translates the graphic window by vector going from the first COORD to the second COORD. The new display context is stacked in the display stack.
Defining a scale
  SCALE
Changes the display scale without moving the center of the window. The new display context is stacked in the display stack.
Redrawing the graphic window
  REFRESH
Redraws the current display. This operation is very useful to erase unwanted residues that are often present.
Centering the display
  C_MASK COORD
Centers the window on the selected point COORD. The new display context is stacked in the display stack.
Redrawing the previous display
  PREVIOUS
Goes down one level in the display context stack. The previous display context is restored.
Note: this context always exists because all eight levels are initialized by default.
Redrawing the next display
  NEXT
Goes up one level in the display context stack. The next display context is used, see note above.
Drawing the whole display
  SHOW_ALL
Computes the mask so as to show the whole database and displays it full screen.
