Modulefpreviousupnextcontents[BIG][Normal][small]
Next: 3.6 Changing the type of a Up: 3 Manipulation of structures and miscellaneous Prev: 3.4 Creating a D.S. NOPO Contents
3.5 Changing the type of a D.S. MUA
Module CSAMAT changes the type of a D.S. MUA, i.e. changes to a D.S. AMAT with compact storage; it also allows to compress the matrix (see also CCMUA).
     SUBROUTINE CSAMAT(M,RAPORT,NFACTO,NFMUA,NIMUA,NFAMAT,NIAMAT,NTAMAT)
C ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
C AIM : ELIMINATE THE COEFFICIENTS A(I,J) OF THE I.D.S. MUA SUCH THAT
C ---               ABS(A(I,J)) < ABS(A(I,I)) * RATIO
C       MUA IN DIRECT ACCESS ( INPUT ) ==> AMAT SEQUENTIAL ( OUTPUT )
C              OR SEQUENTIAL
where
If NTAMAT is non-zero, the associated descriptive arrays must be input (see above).
