Next: 3.7 Eigenvalues and eigenvectors of a
Up: 3 Manipulation of structures and miscellaneous
Prev: 3.5 Changing the type of a
Contents
Module TAMMUA changes the type of a D.S. AMAT, i.e. changes to a D.S. MUA.
SUBROUTINE TAMMUA(M,NFAMAT,NIAMAT,NFMUA,NIMUA) C +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ C AIM : TRANSFORM AD.S. AMAT IN MAIN MEMORY INTO A D.S. MUA C --- IN DIRECT ACCESS C +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ C INPUT PARAMETERS : C ------------------- C M : SUPER WORK ARRAY C NFAMAT : FILE NUMBER OF I.D.S. AMAT C NIAMAT : LEVEL NUMBER OF I.D.S. AMAT C NTMUA : NUMBER OF ARRAYS TO ASSOCIATE WITH THE D.S. MUA C OUTPUT PARAMETERS : C --------------------- C NFMUA : FILE NUMBER OF THE I.D.S. MUA C NIMUA : NLVEL NUMBER OF THE I.D.S. MUA C ..................................................................... C PROGRAMMER : MARINA VIDRASCU INRIA JANUARY 1987 C .....................................................................
where
