Next: 3.8 Miscellaneous
Up: 3 Manipulation of structures and miscellaneous
Prev: 3.6 Changing the type of a
Contents
Preprocessor VVDSXX changes the type of a D.S. VVPR, i.e. changes from double to single precision.
Preprocessor CODEXX is used to plot the eigenvalues. It constructs, using D.S. VVPR, a file used to employ TRACXX to visualize the eigenvalues.
To plot the eigenvectors, we use preprocessor COBVXX, which constructs a B structure containing one or several vectors using D.S. VVPR. Preprocessor TRMCXX is used to visualize these eigenvectors (in the form of deformations or velocity).
