Next: 2.2 Two-dimensional meshes TRNOXX
Up: 2 Visualization of meshes
Prev: 2 Visualization of meshes
Contents
It is possible to visualize two-dimensional, surface and three-dimensional meshes. The contents of each mesh is read from file, stored in the form:
The modules are able to process several meshes (or files) until such a time as the memory available is saturated. Numerous possibilities are offered to:
Preprocessor TRNOXX or REFEXX will be employed (see also TRMCXX or TRC3XX due to the utilization limits of TRNOXX).
TRNOXX is described in section 2.2 for the two-dimensional case, and in section 2.3 for the three-dimensional case. REFEXX is described in section 2.4.
