Next: 5.4 Complete description of the module
Up: 5 Visualization of surfaces
Prev: 5.2 Aim and utilization limits
Contents
Preprocessor VIS3XX is used to call the plot module. It corresponds to module VIS3D which can also be called by writing a main program with the following form:
COMMON M(20 000) LM=20 000 CALL INITIS(M,LM,0,0) CALL VIS3D(M,LM,F) STOP END
If the user wants to use an external function, F, it is necessary to include the following statement in the above program:
EXTERNAL F
and add the functional description to the main program:
FUNCTION F(X,Y) --- --- description of the function --- RETURN END
Naturally, the above program must be linked with the library(ies) required for execution.
Before seeing how the above program runs, we first give a short overview of the dialogue obtained when executing the program. We have:
An initial state (one or several values), which can be modified, is proposed for each choice.
The return key is used to exit from the subroutine (or commands level) in progress.
The next section gives the details regarding the possibilities offered in each of the cases mentioned above. Note that a call via VIS3XX results in the same operations, except for a few details (at the beginning).
