![[BIG]](../icons/zoom18.gif)
![[Normal]](../icons/zoom14.gif)
![[small]](../icons/zoom10.gif)
Next: 7.3 Diverse
Up: 7 Implementation notes
Prev: 7.1 Trees
Contents
Definitions corresponding to the computer terminal:
COMMON/ COMTRU /ITERM,IPAR(10),IELEG,LUXE,NDI23
- ITERM : parameter defining the terminal,
- IPAR(1:10) : supplementary parameters for the terminal,
- IELEG : 0 no general legend, 1 if not,
- LUXE : 0 hard, 1 soft for printing characters,
- NDI23 : plot space dimension of characters (2 or 3).
Definitions corresponding to the extrema of the D.S. under consideration:
COMMON/ COMTRO /NUMBER,NBRESD,MODSD(10),XMIO(10),XMAO(10),
YMIO(10),YMAO(10),ZMIO(10),ZMAO(10)
- NUMBER : number in the stack of the D.S. under consideration,
- NBRESD : number of D.S. to consider,
- MOSDS(1:10) : if MODSD(I) = 1, then D.S. I was modified, 0 if not,
- XMIO(1:10), .. ZMAO(1:10) : object's extrema (I=1:10).
Definitions of windows:
COMMON/ COMTRF /XMIF(6),XMAF(6),YMIF(6),YMAF(6)
- XMIF(1:6), .. YMAF(1:6) : extrema of windows (I=1:6).
Definitions of 2D masks:
COMMON/ COMTRM /XMIM(10,5),XMAM(10,5),YMIM(10,5),YMAM(10,5),
PILE(10),IDEP
- XMIM(1:10,1:5), .. YMAM(1:10,1:5) : extrema of mask J (J=1:5) of object I (I=1:10),
- PILE(1:10) : PILE(I) is the position in the stack of the visualization context of object I,
- IDEP : 0 context not modified, 1 if not.
Definitions corresponding to a 2D zoom:
COMMON/ COMTRZ /IEZOOM,XMIZ(10),XMAZ(10),YMIZ(10),YMAZ(10)
- IEZOOM : 0 automatic objet, 1 zoom, 2 delete (move points), 4 display (same),
- XMIZ(1:10), .. YMAZ(1:10) : extrema of 2D zoom.
Definitions corresponding to 3D zoom:
COMMON/ COMTGZ /IEZOM1,CUBE(2,3),PVUNEW(3),ALFNEW,BETNEW
- IEZOM1 : zoom indicator
- CUBE(1:2,1:3) : extrema 3D zoom box,
- PVUNEW(1:3) : new observation point
- ALFNEW : span defined by a zoom (plane 1),
- BETNEW : span defined by a zoom (plane 2).
Size of screen:
COMMON/ COMTRT /IETAI,XMIT,XMAT,YMIT,YMAT
- IETAI : 0 automatic size, 1 if not,
- XMIT, .. YMAT : extrema in cm. of the box input by the user.
Definitions corresponding to the D.S. under consideration:
COMMON/ CTRQNO /NUMNO,NUMB,NINOPO,NFCOOR,NICOOR,NFB,NIB,NOPTRA,
NFICBE
- NUMNO : number of object (mesh) under consideration (from 1 to 10),
- NUMB : number of object (solution) under consideration (from 1 to 10),
- NINOPO(1:10) : level of D.S. I (nopo or mail),
- NFCOOR(1:10) : file of D.S. I (coor),
- NICOOR(1:10) : its level,
- NFB(1:10) : file of the solution D.S. I,
- NIB(1:10) : sits level,
- NOPTRA(1:8) : plot option,
- NFICBE : number of Benson file.
Definitions corresponding to D.S. under consideration (type character):
COMMON/ CTRQSD /NOMNOP,NOMB,NOMCOO
- NOMNOP(1:10) : name of D.S. I (NOPO or MAIL),
- NOMB(1:10) : name of D.S. I (solution),
- NOMCOO(1:10) : name of D.S. I (COOR).
Coplanearity criterion:
COMMON/ COMEPS / EPS
- EPS : coplanearity criterion.
Addresses and indicators:
COMMON/ COMVI1 / INAF2,INAFI,IAMAIL,IALITY,IALIPO,II12(7)
- INAF2 :
- INAFI :
- IAMAIL : address array of MAIL
- IALITY :
- IALIPO :
- II12(1:7) :
Existence (type logical):
COMMON/ COMLOG / EXIST,EXISTM,EXISTD,CONANC,LCUT,ALL,SOFTCO,
REMPLI,TRACFL,LVIDE(10)
- EXIST :
- EXISTM :
- EXISTD :
- CONANC :
- LCUT :
- ALL :
- SOFTCO :
- REMPLI :
- TRACFL :
- LVIDE(1:10) :
Definitions corresponding to a solution:
COMMON/ COMCHA /IELEM,LINDIC,IEQUI,NEQUI,NDSMT,NDT,NTAB4,IFLEC,
VALMIN,VALMAX,SHRINK,RAPORT,FLECHE,VMIN,VMAX
- IELEM : element selection,
- LINDIC : depends on IELEM, number of items selected,
- IEQUI : choice of isovalues,
- NEQUI : number of isovalues,
- NDSMT : load case to be considered (between 1 and NDSM),
- NDT : d.o.f. under consideration,
- NTAB4 : number of array B4 under consideration,
- IFLEC : arrow option,
- VALMIN : minimum solution value retained,
- VALMAX : maximum solution value retained,
- SHRINK : shrink coefficient,
- RAPORT : amplification ratio for the deformations,
- FLECHE : maximum arrow length (in cm.),
- VMIN : solution extrema,
- VMAX : solution extrema,
- LVIDE(1:10) :
Definitions corresponding to a cut:
COMMON/ COUPES /IDFCOU,NBCOUP,NTYCOU(NCOUP),COUMIN(NCOUP),
COUMAX(NCOUP),NDLCOU(NCOUP),COUPMI(NCOUP),COUPMA(NCOUP)
- IDFCOU : 0 automatic cut, 1 manual cut,
- NBCOUP : number of cuts,
- NTYCOUP(1:NCOUP) : (maximum NCOUP set equal to 7) type of cuts (values, derivatives, ...),
- COUMIN(1:NCOUP) : extrema of function I,
- COUMAX(1:NCOUP) : extrema of function I,
- NDLCOU(1:NCOUP) : d.o.f. corresponding to cut I,
- COUPMI(1:NCOUP) : extrema of cut I,
- COUPMA(1:NCOUP) : extrema of cut I.
Legends in X and Y, and curve legends:
COMMON/ LEGEN2 /LEGX(10),LEGY(10),LEGCUR(20,10)
- LEGX(1:10) : legend for the X axis of plot I,
- LEGY(1:10) : legend for the Y axis of plot I,
- LEGCUR(1:20,1:10) : legend for curve I of object J.
Graduations (X axis):
COMMON/ TRGRAX /IDEFGR,IMODX,ITRACX,NBINTX,NBSUBX,XLONG,IFORMX,
TAIXX,TAIXY
- IDEFGR : automatic definition of axes if 0, manual if 1,
- IMODX : definition mode for graduations,
- ITRACX : graduation mode (linear or logarithmic),
- NBINTX : number of intervals,
- NBSUBX : number of sub-intervals,
- XLONG : length of an interval (depending on IMODX),
- IFORMX : number format,
- TAIXX : reduction/enlargement factor of characters in X,
- TAIXY : reduction/enlargement factor of characters in Y,
- IQUAD : 0 no grid, 1 if not.
Graduations (Y axis):
COMMON/ TRGRAY /IMODY,ITRACY,NBINTY,NBSUBY,YLONG,IFORMY,
TAIYX,TAIYY
- IMODY : definition mode for graduations,
- ITRACY : graduation mode (linear or logarithmic),
- NBINTY : number of intervals,
- NBSUBY : number of sub-intervals,
- YLONG : length of an interval (depending on IMODY),
- IFORMY : number format,
- TAIYX : reduction/enlargement factor of characters in X,
- TAIYY : reduction/enlargement factor of characters in Y,
Differentiation graphics for a curve plot:
COMMON /TRCARA /ICOUL(20),ITRAIT(20),ITYPE(20),ISYMB(20),
ITAIL(20),IEPAI(20)
- ICOUL(I) : color for curve number I,
- ITRAIT(I) : graphics (solid, dotted, ...) for curve I,
- ITYPE(I) : type of representation (line, symbol, histo, shading, ...)
of curve I,
- ISYMB(I) : symbol number for curve I,
- ITAIL(I) : symbol size factor for curve I,
- IEPAI(I) : thickness of curve number I.
Material definition (plot of stresses):
COMMON/ COMSNU /SEUILP(5),COHES(5),FRICTI(5),XNU(3,10),NEPLAS
- SEUILP(1:5) : plasticity threshold of material number I,
- COHES(1:5) : cohesion coefficient of material number I,
- FRICTI(1:5) : frictional angle of material number I,
- XNU(1:3,1:10) : Poisson coefficients (isotropic, orthotropic) of material I,
- NEPLAS : number of plastic elements.
Next: 7.3 Diverse
Prev: 7.1 Trees
Contents
